Fixing cork to baseboards
(In Topic #8911)
Should this be diluted or straight from the container. Does it matter ?
I'm not anywhere near ready to commence my baseboard construction yet but I'm asking the question anyway.
Cheers Toto
the amount of PVA on the cork should be just enough for a very small amount to appear from under the cork once the roller has been used, so as you know it has spread to all the underneath of the cork. After rolling, ordinary house bricks are placed on the cork to make sure it stays in place until the PVA has hardened, and set,- I usually leave it for 24 hours. Doing this makes sure it is perfectly flat to take the track, many running problems are caused by uneven track. I use PVA to fix the track down, and again using the bricks again, but with cardboard sandwiched between to prevent damage to the rail tops, which is discarded once the PVA has set,- and the bricks removed . Hope this helps :cool:.
Last edit: by bike2steam
There has be some discussion about the sound deadening qualities of cork and it seems that, if the ballast touches the baseboard, i.e the space between rails and baseboard is bridged by the ballast, there is virtually no insulation. Keep the two apart, and it works much better - hence my complete cork cover.
I've never tried Copydex but it sound good - although expensive ……………:roll::roll::roll: I use "builder's PVA - comes in buckets from builder's merchants and is much, much cheaper than the woodworking brands.
Ken
But it's extremely expensive Ken. At least, it is over here. If you mean the brown stuff that looks a bit like runny putty, a small tub (500ml :roll::roll::roll:) costs around 6 euros. It will do around 6 square feet-ish ………………:hmm
Having said that, yes it is very good glue for cork thumbs:thumbs
I will be covering the whole baseboard in cork too. I'llgo with neat PVA as I have a load of it already. I thought that it would have been dried Ian lot quicker though. 24 hours……..oh we'll.
Thanks again
Toto.
That's the stuff Peter but it's very thick when new! It only goes runny when it's left for a long time but amazingly still has excellent adhesion - and it goes further too! ;-)
…………..If you mean the brown stuff that looks a bit like runny……………
Ken
Putty, here, is very solid and comes in either "white" or brown. The cork glue I've used is the same colour as the brown putty but far less dense. You put it on with a spatula - it's far too stiff to brush on ……………
We're talking about the same stuff and yes, it is very good glue, dries quickly, and is nearly impossible to remove once it on. However, it's still expensive …………….;-):cheers
Simon
Wayne
Modelling the railways of South Australia of course
I use foam underlay, glued down with PVA on to a 6mm ply base, as all my track is approx 90mm above the baseboard, I have used 50mm insulation board as risers.
The underlay is from B&Q (other suppliers are available), and costs around £20 per pack - 5m x 1m pack. Do not use solvent based glues on it.
Paul
I think it's a closed cell plastic type material. I have wondered about that heavier green underfloor stuff before. It's like the old soft fibre insulation board but denser. On the other hand, it may "drum" a bit…..:hmm
Looked up Plastazote and of course there are many different densities etc:roll:
Have you any idea what the Noch and Woodland Scenics ones are?
Simon
I'm not entirely sure what density Noch etc use but I'm using 2mm thick LD45 which looks and feels the same. I think anything softer would be too liable to 'dent' if you happen to press too hard on it.
