Lift up flap best material to use.
(In Topic #9182)
Lift up flap and plywood expansion problem
Hi all,Another of my little posts.
I have a hinged lift up flap on my baseboard build.
Now its giving trouble, Having used a good dense 9mm ply.
The ply has expanded, and said flap has become a right pain.
Would medite or similar be a better material to use for this vital back saver?
I am getting too old for clambering under baseboards!
regards,
Derek
I'm surprised the ply has shifted, did you seal
it when it was first made? That should have
kept it under control.
Also, is it subject to extremes of temperature
and humidity? If it is, I would be more worried
about the whole layout!
Either make a new flap (from ply) or trim back
the original, then give it a few coats of seal,
(matt varnish, floor seal, even diluted PVA)
Good luck, Jeff
Jeff
My layout is in unheated rooms upstairs.
Temperatures the past couple of nights have dropped a lot.
Its marine ply on the flap unsealed I am ashamed to admit.
I will take your advice, Also install a heat source to keep humidity or damp at bay.
regards,
Derek
The heater will control the temperature (obviously!)
But if you have a damp/humidity problem then you need
better ventilation.
You can get humidity controlled extractor fans, not cheap, but worth it considering the value of your layout.
Jeff
Jeff
I will take a look at those humidity jobs.
Also Ron thats a good tip with sanding hinge end and useing aluminium braces.
I will let you know how I get on.
regards,
Derek
The gap doesn't have to be big, couple of mm tops.
What is more important is to have the end of the flap not
cut at 90*, this is so it clears as it lifts.
After all, the longest dimension on the flap is from the hinge pivot to the bottom of the lifting end, if that makes sense!
Jeff
Jeff
Model Railroading on a Budget
Last edit: by Sol
I too am surprised that the ply has moved/swollen, more likely the [presumably] softwood framing has moved as is probably of greater length.
A slightly higher tech solution for layouts in areas of variable humidity would be to align the lifting end on magnetic handbag catches and to fit undersized hinge pins allowing lengthwise expansion whilst lateral alignment would be preserved by the hinge cheeks.
I measured 0.3mm per 150mm over a 50 deg C range (i.e. freezer to outside my Cyprus house in the summer). That if my maths is correct (unlikely) is around 0.009% per Deg C.
I may be working this out wrongly, but I think the temperature range in my garage of about 180C (90 - 260C) means a 1 meter length of Peco flexitrack will expand by about 0.8mm.
So two lengths together will expand over the range by about 1.5mm, which may explain why I had to take up a piece yesterday which I laid in March as it had become unstuck and slightly raised.
Of course, it could be just my naff track laying
(PS OK, I know, I know, Peco flexitrack is still sold in good old yards, 914mm)
Personally I would be more worried about the sub base expanding/contrcting with humidity changes.
Ply top and softwood frame - different expansion coefficients. All that glue in the ply effectively seals the inner layers. Make the frame out of ply, a lot lighter, stronger, and the same coefficient. Is this construction grade ply (5 layers) or furniture grade (9 or more?). Big difference in 'warpability". Dropping the bridge, rather than elevating it, makes life a lot easier as well.
