Baseboards
(In Topic #8230)
any disadvantages ?
I have just stopped working for myself and have a load of bench's built into the loft these are ideal for my new layout apart from they have 6mm MDF tops, there very strong with easy access underneath for routing cablesThey are strong well put together and it would be a shame to pull them out so,
I thought about gluing 5mm Foam Board onto the MDF to create a new surface and use double sided tape to anchor the track down. Can anyone see any disadvantages to this method.
p.s. the layout will never move out of the loft
George
Last edit: by GeorgeWB
I'd tend to go for cork for the surface George but you'd still have to drill the MDF to get the pins in - it's too hard to nail into.
Max uses MDF in Australia - I suspect it might be very slightly softer than the UK stuff but he always drills first.
Of course, with the double sided tape, there's no need to pierce the surface with anything (except point motors) but re-positioning the track might be a problem. I've never, ever laid track in the right place first time around …………..
Last edit: by col.stephens
http://www.thamesvalleysupplies.co.uk/plastazote.php
The LD33 density is about right and I used 5mm thickness, and this is almost identical to the WS product. It's also black so the right colour for a track base. It's very easy to cut, and for the scenic areas I just cut it roughly making sure it was wider than needed. This allowed for adjustments when tracklaying, and once the track was fixed in place it was easy with a craft knife to cut at an angle along the sides to create the ballast shoulder.
The foam is simply glued to the baseboard with builder's PVA, and a slightly better PVA (Evostik Woodworking Adhesive) used to glue the track to the foam bed, with a bead of glue every 2-3 sleepers. This is more than adequate to hold the track in place, even in my storage yards where there is no ballasting.
In my view track pins are difficult to insert, don't look too good and can easily distort the track if you're not careful. The pins also act as sounding posts and will transmit all the track noise to the baseboard.
Last edit: by RFS
Robert
The thoughts behind using 5mm foam board where.
1/ the ability to scribe lines into it for cobbles/sets
2/ improved sound insulation ( so I am told )
3/ the ability to remove a small area and insert buildings rather that sit them on the top
4/ Light weight, takes paint well
5/ the ability to remove the paper on a small are to re-create different surface textures
disadvantages there are always some
1/ easily dented by dropping something onto it
2/ not sure there are any more
Plastazote is a material I have had experience with in a previous life and to be honest had not consider on this occasionbut may well now. interesting how you fastened the track down to it
Anyway must disappear as breakfast calls
George
In fact, to me, in modelling a railway, some could turn into disadvantages.
Well after due consideration I am going to try this out on a small section of the layout first just to see how it pans out and will report back later
Thanks for all the feedback its what these forums are for
George
Last edit: by Gary
