Power poles
(In Topic #7006)
lot more to go such as "planting" them & adding power cables.
I particularly like the "long" poles. So often, you see huge conglomerations at the top and a pole which would be about a scale 6ft high !! Yours are desigend to keep the wires well up out of harms way.
So you'll need poles with transformers, maybe poles with isolating equipment, and of couse guy wires for any pole where the overhead changes direction, even slightly.
Stu
Not necessarily Stu. :hmmThey look great, don't forget that domestic premises only had two wires (2-phase,240v) whereas what you have made is 3-phase, 415v, which would go to farms, industrial units, etc.
We had 3 phase because our "hamlet" was some distance from the supply. Using 3 phase, they could "balance" the phases and avoid any potential overloads.
Also, I presume the supply Sol is talking about is for the Chard yard so it would almost certainly be 3 phase. As you say, he will need a transformer on the final pole ……….:roll:
For a yard, there might be a ground mounted transformer, rather than a pole one (or twin pole one).
All of which makes for interesting and not often modelled detail.
Some of our domestic homes has 3 phase & others in the same street have 2 phase.
A large ground transformer (perhaps fenced off like a mini sub-station) would make an interesting little feature, or you could mount a smaller one 2/3rds up the pole.
The only installations (very rearly) that had a 2 phase system were premisis that carried out welding using a 2 phase welding machine.
Just finkin, another visit to the tip 'praps?
[Nice poles, will you dip the screw heads in off-white paint?]
From the photo, it appears that there are 4 wires running down the street, one neutral & 3 actives with homes being connected the actives being used in turn presumably to be able to isolate areas/homes.
If this is the case, then I could use the middle insulator for neutral & have two actives - one serving the shed & the other to my switch box on the ground that will serve the station. In theory, the switch box can isolate platform lights, station building & the now defunct signal box.
But I have options - even my switch box could be a transformer, my current area where I live, they are all mounted in cream cabinets on the ground.
As a point of interest TT stands for "terre terre" from the French "earth earth", hence there is no earth cable on the poles because the system uses the general mass of earth by means of earth rods at source of supply and at the users end.
I know that system is called "SWER" - Single wire, Earth Return. A small pole mounted transformer is close to the rural house.
http://en.wikipedia.org/wiki/Single-wire_earth_return
camera shoes up all the mistakes !
I think I wlll make an new one that is more squatter - like the photo above in a preceeding post.
weeds required to grow plus some weathering on the Transformer box.
I do however, like the guy wires very much. :thumbs
I tried adding proper wires tween the two poles but not successful so I am getting some fine Boingo wire
http://www.modellers-warehouse.com.au/Wild%20places/Oingo%20Boingo%20line/scalemodelinglin.html
Do I take it you'll have lots of fruit vans then ?…………………………. - almost the same size as the real cream unit ………………………..
At .08MM or .003" that has to be like (or smaller than) a human hair!
Amazing, you will have to show us a photo of that. If you can.
Wayne
