The Viaduct
(In Topic #6225)
The photo below supplied to me by John Wiffen ( with thanks) shows part in brick, mine will be with random Ashlar stone.
Now the fun starts & to make it interesting, on a slight curve at one end & a rising gradient at the same time.
Pete
Last edit: by wogga
Pete.
Pete.
showing the curve that will be needed & at the same time climbs nearly 25mm/ 1 ".
That was the easy part - now the fun starts !!!!! as I intend to try to build it in situ.
That part was easy - now to start on the arches.
Note that in this station, no other track base will be used to raise the track above ground level. I have glued cork over the entire station area & the reason for this will become clear when I commence track laying.
[line]
The track is not anchored down yet so I can include a curve again.The curve seems to have gone, Sol.
Of course, with my viaduct on a gradient, the arches look like this
they are supposed to be under the track base so I cut another single arch out, glued to thin card & cut to fit as a temporary means
as this was successful, I am now gluing the back piece onto the proper arch & will test it again later. Each arch will therefore be a separate entity.
This is what I get for diverting from the norm !
The curved part of the arch used a paint tin slightly smaller than needed to get a smooth curve
The two sides now joined with the arch which had to be shortened.
Another 5 arches to go & be joined with buttresses then work on the top walls, etc.
To hide the white edges, as my texta of the correct colour had run out, I used weathering powders rubbed with my finger.
Are you going to fit a parapet on top of the trackbed and, what did you use to make the copings along the trackbed - looks good ?
The hardest part is cutting the thick card for the arches.
The Avocado is the colour I paint my facias like this
What is the covering under the arches - above where the stone piers stop.?
