4 Bogaduck Road, STIRLING
(In Topic #5707)
A look around.
4 Bogaduck Road, STIRLING, South Australia is in a suburb of Adelaide about a half hour drive from the CBD. This is a typical visit to a street which runs along the main railway line between Adelaide and Melbourne. Many passenger and freight trains use this line each day. These shots could have been taken in hundreds of other locations along the line. Enjoy.
Fences? Wot fences?
Your Stirling looks much warmer :sad:
Some great photos you have taken there thanks for sharing them
In the third phot the round container at the side of the track is that the engine drivers dunny stop place or something?
It is padlocked and it has a plug-in power line leading down from the top of it. The top appears to be mesh rather than solid suggesting a need to dissipate heat or a requirement for air circulation. The wire leads towards the roadway (and is visible in shots 3 and 4) and not towards the greaser which is, as most are, purely a mechanical device without an external power source.
I am also intrigued by the fact that the cable hangs vertically in shots 3 and 4 but is clearly at an angle in shot 5 as though it has been pulled from ground level towards the roadway.
I would suggest it might be a pump house for water given that there are tanks just behind it, or failing that might be a battery to power a road warning device such as a flashing light which is out of shot but would warn of an approaching train. Of the two I would favour the pump housing.
Its deffo a driver dunny drop the power to it is for the mincer to chop up the pooh:lol::lol::lol:
The mesh on top is to allow the stink to get out to stop build up of explosive gases
. . . and? Don't keep us in suspenders, Sol. :shock:
The train controller could still be at work & Bob B is not one for visiting e-mails, etc like we do.
When I find out, so will you a bit later than that.
Patience is a virtue so I am told
