New Tramway
(In Topic #4399)
Here's the framework and the nook where the computer is to go.
. . . and from the other direction.
Aha! An interloper. Caught in the act of ebaying! I'll sneak up on her . . .
Rats! She heard me coming . . .
Our youngest, Alice. You can see she takes after her Dad - same tummy! Well, she is having a baby, so there is some excuse. ;-)
More work tomorrow.
Last edit: by MaxSouthOz
OK, well then what is your excuse :question
Did not like to ask but now Sol did, i would also like to know the exscuse, is it age , and also how come she got the looks, i mean look at your piture of yourself
I look forward to you doing the tramway
It will make a lovely layout and with it using R &R like you are planning it will be great to watch while you are working at your bench.
The reason Alice is smiling she is looking at Max and thinking "Im glad i look like Mum"
cheers brian
Why are people so unkind?[user=95]Sol[/user] wrote:Our youngest, Alice. You can see she takes after her Dad - same tummy! Well, she is having a baby, so there is some excuse. ;-)
Its going to be interesting seeing you create roadways within the rails around the double slips you are mentionining in the R & R thread
cheers Brian
I note once again that there's no cheap "rough cut timber" for you - that superb aluminium tubing. Just wish it was cheaper here - certainly makes a stron, good looking baseboard support.
I'm looking forward to seeing what our resident "electrickery kid" does with a tramway. It should prove very interesting.
Tramways would probably use back-to-back Y-points to permit the same moves in a restricted space.
There are plenty of street-corner intersections where a # crossover (or "H") is also equipped with curves to make turns. Melbourne has one complete "Grand Union" with all four turns, and several with three out of four possible.
But no actual slip diamonds since these are actual curves with their own sets of points separate to the # crossing in the middle.
The double slips will be in an open, unpaved section. The Bay tramway has a grassed right of way between Adelaide and Glenelg. It's really only paved at the ends, stops and crossings. I'm hoping to hide my double slips outside the terminus precincts in the undeveloped areas.
The St Kilda Museum Tramway has all the turnouts in grassy, unpaved areas. Bushes and trees overhang the tramway and almost touch the trams as they pass. The ballast is the same height as the surrounding dirt, sometimes lower
Another way I could do it is to have a single turnout, running the main lines into a single station, but I think that won't look as interesting as a double track station.
At the end of the day, the point of the exercise is to play with Rr&Co. The tramway is just a bonus.
You spoilsport i was loooking forwrd to you tackling roadway around double slips
cheers brian
Here is the truss:-
It's another length of RHS.
The two wires which carry the lamps are tensioned from one end and there is a tension wire over the top. Light, but strong.
The chains are doubled to allow the assembly to be lowered for maintenance and to complete the work.
These are the three pairs of wires over the main layout. I used high tensile fencing wire and pulled it up with turnbuckles. Because I'm using solid state transformers, the downlights can be dimmed. The dimmer rack is that white floating square on the left.
It's always good to see the "big picture" around layouts and to understand how each of us has tackled issues such as lighting.
Model railways require much more thought sometimes than just the model railway!
Are the lights the type that screw-contact onto a constantly live wire runner or are they fed separately and the wires just carry them ?
Lighting is, to me, always a problem with "fixed" layouts - what to use and how to keep them high enough to allow access for working and yet still close enough to give decent light. Less of a problem on exhibition layouts because they can be built into a fairly low "pelmet".
What works for Max may not work for others and vice versa since we all have our layouts in different situations. Even outside where most of my lighting is natural I have strip lights high above the layout which give reasonable illumination over about half of it at night and some illumination to the rest.
Will also look forward to seeing how this plans out as I had considered a tramway prior to opting for a smaller scale.
