Couplings
(In Topic #13600)
What do you use ?
I didn't really know where to put this so thought maybe "materials" might fit the bill.I currently have a melange of couplings depending on stock manufacture - TL from Hornby, Dapol and Bachmann plus quite a few that I've changed to Kadees.
I have read good reports on some of the other "lesser known" couplings such as Dingham etc. and wondered if Kadee was in fact, the right route to go down. I can imagine with the likes of Dingham, there could be problems reversing.
Whilst I really like the Kadees, there are a few problems associated with them - uncoupling on bends, difficulty in getting the right height on all stock sometimes resulting in unexpected uncoupling and, unless one pre-plans (I never do !!), the siting of under track magnets isn't possible. I've read and re-read the treads on using neodymium magnets but none seem to be ideal so I'm left with the "between the rails" magnets which is expensive and often unsightly.
Which couplers do you use and why plus, are they as near fool-proof as one can expect or, is it the case that Kadees are tops ?
That being said I do like the slimline Bachmann hook type connectors for practicality. They clip inside the Kadee box nicely and fix the problem of detaching whilst on tight radius curves. They don't look too invasive or "toy like" as the typical "D" Hornby/Mainline/Palitoy/Dapol type.
I suppose it all comes down to practicality, cost, and asthetics, in other words personal choice!
research = asking a bloke who knows a bloke who said something vaguely similar to what I wanted to hear! - Tony (aka the Phat Controller)
I'm not currently modelling in oo gauge, but I always though Kadees looked very odd on four wheeled wagons, but looked great on modern image (whatever that is) diesel and electric locos and modern coaches. If you can get the coupling height right though, they do work well as I'm sure Sol will tell you.
Small Backmann tension locks were my final choice for oo and are my choice for O-16.5. Look ok on four wheeled stock and you can automate them with the Kirby/paper clip and magnets uncoupling system, or even some sort of uncoupling ramp (not necessarily the Peco ones).
PS Currently having a similar dilemma with standard 009 couplings or Greenwich couplings
Both at home and in the public view, I used a number of bent wire contraptions to couple and uncouple - all relying on the "hand from the sky" approach. Total PITA.
Nowadays, I use the slimline TL couplings although height remains an issue as not all buffers on stock are level (???).
I use a home-made uncoupling device rather than relying on ramps so I can uncouple anything anywhere. That still means the "hand from the sky" but as its only a private layout, thats OK for me.
I have never used Kadees as they have a reputation for being fiddly - whether this is fair or not I'm not sure.
We all have our personal preference which are mainly dictated by price, practicability and whether we can be bothered to actually change from the stock coupling supplied with the rolling stock.
For my 3 penneth worth, like you, I have a mixture.
My couplings are either the ones supplied with the rolling stock/loco's or Spratt and Winkle.
The Spratt and Winkle are a joy to put together if you like the solder gun and are less obtrusive than the normal ones supplied.
Your choice of coupling will also be governed by the lengths that you may wish to go to, to un-couple.
My lay out doesn't have magnets but strategically placed servos under the base board that operate a suitably disguised 'plate' between the rails to lift up the 'hook'. It also works with the Spratt and Winkle coupling with a bit of extra solder to a tag that hangs down from the coupling plate to meet the servo plate in the rails.
It is easier than it sounds. The servos are operated through an Arduino circuit board and I have the programme if any one wishes to have a bash.
Long winded but I hope of some help.
Gary
I also use Kadees for inter-unit couplings for EMU stock. Many of these have conductive couplings within the sets, but work better with fairly rigid couplings between the units when in multiple - all of my Bachmann MLVs, 4 CEPs and 2 EPBs have Kadee #20 couplings at the outer ends, as do the Hornby 4 VEPs, 2 BILs and 2 HALs. Bachmann's 2H DEMUs are similarly treated.
Intermodal and bogie container wagons also get Kadees fitted.
It may seem a little counter-intuitive that I use the Kadees for fixed sets rather than for convenient magnetic uncoupling, which is their most touted feature, but they do provide a more rigid coupling between vehicles allowing the close-coupling mechanisms to adjust in and out, where the tension locks don't really work well for this.
That said, next layout will have 3 link chains, sprung buffers and shunters poles from the sky. Decoupling where I want, and no magnets to fix between or under the rails.
All couplers are a compromise. Even Kadees on NA stock. Kadees on 4 wheel UK wagons when short coupled look no worse than tension locks. If you have fixed rakes there is a large range of 3D printed UK prototype couplers available on Shapeways.
I live with the unsightly magnets that I have scattered all round the layout.
The height gauge and adding plastic shims help with the height variance. Although I continue to get irritated with the droopy dapol version
I agree with Nigel……they look no more out of place than tension locks, particularly the old ones, on 4 wheelers.
N gauge dingham don't go that small so probably spratt and winkles once the layout is ready to run.
Regarding Kadees, I think their look is perfectly acceptable from normal viewing distance - this isn't a layout for rivet counters - but I do get frustrated by several of their "quirks" in addition to the difficulties getting the height perfect.
I use the height gauge and, on some stock, that requires quite a bit of butchery and effort. As I said earlier, I do occasionally suffer from an unexpected, and unexplained, uncoupling. As John said, the visible magnets don't really bother me, in fact, I prefer the between the rails magnets to those under the tracks - I can easily adjust tracks, and building placement, without having to worry about moving magnets. I think my main concern is that one has to decide exactly where one wants to uncouple - that, I find, requires forward planning - not good news for me ……………
I hate the old massive "D" TL's but aggree with others in that the modern small TL's don't look at all bad and, with a scratchbuilt "tool" are easy to uncouple - but then so are the Kadees ………………………………….if I can conquer the aforementioned snags !!
Only issues I found with Dingham couplers are they are fiddly (6 or 7 bends) and need some very fine soldering work to make, and they are handed. Which can pose problems. Still basically a hook and loop coupler that needs to be accurately positioned both vertically and horizontally. And works best with sprung buffers.EM gauge Dingham, I think the best looking auto coupler. Many years ago I used spratt and winkle, Appropriate since the MSWJR had running powers on the spratt and winkle line.
For those in N scale Micro-Trains do Magna-Matic knuckle couplers.
Also, how will you cope with any points or crossovers - surely they'll be less than 6ft radius…………. :roll: :roll:
The N gauge layout has priority at the moment, as I'm occupying a section of the MRC, the EM layout of a lifetime will really start advancing when I retire in 3 years time..
What a fantastic space to work in - I'm so green. I had about 30ft x 15ft for the old Maxmill and, in places, even that was a bit tight.
Hurry up and retire so we can see this masterpiece evolve. :thumbs
Off topic slightly, but 35 feet is only around 0.5 miles in 4mm scale. Six feet radius is about 430 feet. Still tight for mainlines compared to prototypes. But ideal for model couplers that can work with sprung buffers.I'm very slowly building an EM gauge model of Ludgershall Wiltshire, it will be true scale with points as per the dimensions of the original. The shed I've built for it is 63ft by up to 16ft wide, 53ft length for the railway, the station itself is 35ft long. It's something I particularly want to do, the track has to be right, my grandfather was ganger there.. The 6ft radius is the width of the shed at the narrow end ( the shed is on a wedge shaped piece of land.
