(In Topic #8355)
The following posts have been moved here from the "Maxmill Electric Tramway" thread with the agreement of their authors.
Joined: Mon Jan 14th, 2013 Location: Keighley, United Kingdom Posts: 9 Status: Offline
Gallery photos
I use DeltaCAD to draw up the body and then transfer to DrawPlus for colouring in. So far I have made a lot of various bodies in various colours. It is also pretty easy to try different scales. Living as I do in a once 4 feet gauce zone I generally stay local, use 1/76 scale for 4 feet. I have tried 1/64 S which means 16.5mm represents 3' 6". I have also made 0, 1 and G gauge bodies. The latter were meant for meccano chassis and as yet has progressed no where.
Being more interested in the technology than the trams themselves I discovered the various methods, past and present of wireless electric trams. I quickly realised that this easily represented by 3 rail track. Acquiring some Hornby for trials I became a fan of this really lovely tinplate track. Even making three rail is straight forward thanks to Peco who provide suitable fittings, and also 'studding' for Marklin style stud contact - which is actually more realistic of the prototypes that a continuous third rail - except there is a system in use that while intermittent looks continuous; Ansaldo I think make this. Bombardier make an induction system, same method as electric tooth brushes.
Finally there is the ability with some three rail systems to indulge in a basic type of automation really suited to tramways. Unfortunately it does not work with Hornby track but will with Trix Twin, or any system where the running rails are still insulated from each other. Of course it also works with and overhead supply. It was seeing a small figure of 8 layout with three trams running on it that introduced me to the concept.
It is all work in progress but soon hope to have a reasonable demonstration layout for my different approach.
David
____________________
Joined: Tue Jan 29th, 2013 Location: Bradford, United Kingdom Posts: 31 Status: Offline
Gallery photos
I'm not too far from you here in Greengates.
As far as I am aware the trams never quite got to Keighley. They stopped in Crossflats but since I was living in Clydebank when the trams stopped running in Bradford I don't know for certain.
I can not afford to use DeltaCAD, I'm stuck with AUTOCad 2012 so I have no templates for this kind of work but at least I can make them.
If you are going "freelance" I have a whole set of freebies from here, http://www.brusselspapertrams.be/downloads.html and when I find out how to insert this as a link I will.
I also have some other free downloads which might suit you and since they are free to download I can put them on here providing I leave the originators name on the file.
The Brussels jobbies include some spiffiy Bombartier style (need to check to see what they are) and some older four wheel stuff.
The buildings are Scalescenes low relief garages
Jim
Joined: Mon Jan 14th, 2013 Location: Keighley, United Kingdom Posts: 8 Status: Offline
Gallery photos
Actually Keighley also had a 4' tramway. It got as far as Riddlesden or thereabouts. It was never connected to Bradford although I suspect the use of 4' gauge meant it was a rounf2it that never happened.
DeltaCad by the way is not an expensive CAD package and for the casual hobbyist is far easier to learn than AutoCAD. I am now on version 8 having upgraded since I bought the first version about 12 years ago. When I too had access to AutoCAD I much preferred DeltaCAD.
All I do is save the drawing as a .dxf file and DrawPlus from Serif loads it OK. All one has to do is make sure the layers are not merged. Only bit of work before colouring is to put the layers in order.
Thanks for the links, I think I have found some before.
For the most complex card model try Canon and Yamaha - the latter have card models of motorcycles to download. They are terrifying in there complexity.
Up to now it has all been playing around and trying out. I am now getting serious and going to try and produce some real models. Will post my efforts.
David
Joined: Tue Jan 29th, 2013 Location: Bradford, United Kingdom Posts: 30 Status: Offline
Gallery photos
Not a great distance apart then. Mind you there were many local and municipal lines which ended like that.
A word of caution regards the Brussels paper trams. They are fine but not to scale. I simply resized the entire page in Photoshop since I had the wheelbase to work from. There isn't much in it but it is noticeable. If you want current Brittish trams Nottingham have a freebie but it is nearer N gauge.
Joined: Tue Jan 29th, 2013 Location: Bradford, United Kingdom Posts: 29 Status: Offline
Gallery photos
Got interupted by a culinary emergency so I’ve had to come back and do this.
Possibly the best card tram kits are from Elena & Robert Hardy at elrokits@btinternet.com and they are certainly a quick education in what to aim for in a card kit.
So far I have got as far as the pics below with the developement of my Glasgow stuff and when I have got it to a sensible kit I will go with a Bradford standard. If you have any plans or pics of the Keighley stuff I would like to have a look at them.
Standard Tram
Coronation Tram
Jim
Joined: Mon Jan 14th, 2013 Location: Keighley, United Kingdom Posts: 7 Status: Offline
Gallery photos
You are in a different league to me. I have tended towards quantity over detail: technical note - I have not used the term quality as I recognise quality as meaning fit for purpose; mine might look rough, be short of detail and freelance. However they are fit for the purpose.
These are grafic pictures of some of my tram designs. These were all created to fit on old Underground Ernie Chassis.
Joined: Tue Jan 29th, 2013 Location: Bradford, United Kingdom Posts: 28 Status: Offline
Gallery photos
Can't see anything wrong there. They are up and running and I'm still developing and hunting for a way of getting bogies or a truck under mine.
Where are you thinking of running the Aire Valley Tramway from and to? Keighley to Howarth would be good and you could do a "toastrack" for summer visitors to Bronte country (assuming we ever get a summer) and Skipton castle would be a good northern end.
You are not as freelance as you think! Take a look below
The bottom one is Hong Kong
Jim
Joined: Sun Jan 13th, 2013 Location: Malmesbury, United Kingdom Posts: 45 Status: Offline
Gallery photos
Kind Regards
Aaron
Joined: Mon Jan 14th, 2013 Location: Keighley, United Kingdom Posts: 6 Status: Offline
Gallery photos
On the topic of CADCAM and 3D printing. Still saving for a 2D CNC card cutter - there is one!
The Bankie
Joined: Tue Jan 29th, 2013 Location: Bradford, United Kingdom Posts: 27 Status: Offline
Gallery photos
Yes there are places who deal commercially with 3d printing and I even know a guy in Bradford who could do laser cutting, BUT, we come back to price and for small runs you need to pay for everything including the developement and postage.
Cheapest 3d printer I have found is A$650 and you need to build it when it arrives from Oz. Don't bother looking up lazer cutters as they tend to be heavy duty commercial card or fabric cutters and WAAAAAY overpowered for small scale card cutting.. The "Craft Robo" cutters are good for plain card designs but have difficulty with coloured designs due to possible registration errors. I used one and could not get it to be accurate enough to avoid either white bits or cutting into the coloured portions of the job. You need a plain black/white template and then have to use that to cut a coloured print out.
However if you want to use the designs as test pieces for the students:mrgreen:….
I think I'll have another look at "Craft Robo" since it was about 3 years ago I tried one. May be some upgrades.
The final option is a cutting plate like a jigsaw cutter but at around £140 per plate and either of the trams will need four plates I am looking at £560 for each design:sad:
Jim
The Bankie
Gallery photos
In contact with Jeff at Creative Printers cplsales@print1.co.uk regards cutter but you need to use a template or you confuse the machine and it cuts EVERY line. So you need to use the template and register the two together.
Jim
The current result is that CPL say they have a machine capable of cutting the card but have no idea if it will cut the acetate needed for glazing. I could just bout live with that but I feel that if I wait a bit 3D printers might come down in price enough to let me afford one.
I have asked for a quote from a lazer company so will give us all a good laugh later when I get it.
Peter
I like the new position for the avatar.
Jim
One use of 3D printers is for them to print the model in wax. This can then be used to form a complex lost wax mould. Usually referred to as one of the oldest casting techniques. A film on TV about Rolls Royce showed them using the technique making jet engine components.
As a one time production engineer I am following this technology with some interest. I hope the model industry is too. Airfix could become an information company from who one downloads the model kit data for ones home 3D printer. I wonder?
David
PS
Now back to my card trams.
index02
index02
If you Google "Grime Street", there's a guy who is marketing some 3D printed Leeds trams for, I think, around the £40-ish mark.
They are wonderful scale models with all details included. You do of course, still have to add the motor and other "electrical" bits.
I do not usually go in for such precise predictions so I might be way out, but with fast changing technologies it is hard to tell.
David
index02
index02
Again .gif hence the black background.
index02
index02
index02
index02
Since we are putting up models here's one I prepared earlier:roll:
As you can see it's a Brussels tram and is a free download from the "Brussels Paper Trams website. I have rescaled it for 00.
Peter this is a free download with permission to copy so there is no copyright infringement providing the source is acknowledged and no charge is made.
The .PDF at http://www.brusselspapertrams.be/7821.html downloads The tram below BUT be warned it is NOT 00 gauge.
Print 7016 out at 1:1 and you will have a 00 gauge tram.
Have fun
Jim
Last edit: by The Bankie
