Water water every where
(In Topic #1499)
1 Prepare the base this is the subjective bit Ive chosen a beach this time, the principals are the same light colours first darken for depth, unless you want an underwater shelf effect Id try and merge any changes of colour. I use Acrylics as they suit my style (fast drying)
Sand Colour
A mix of Sand blue and green (thas not really Mrs RJRs best tuperware !)
Silicone (the pics speak for themselves) the spreader is scrap balsa, apply and spread about a bit
The second layer, the first is still wet. I find the second layer easier to handle as the first one, you have to apply a reasonable amount of pressure to ensure the base it completely covered. The spreader is held along the required waves. ( I have several precut and throw them away when they get too sticky)
Once you have the general look the silicon can be teased up by touching the spreader on the surface and teasing the silicon up.
The biggest trick is to add some scenic distraction to stop people looking too closely at the water…. In this case a bikini !! At this stage the white enamel paint is gently added to the crest of the waves with an old brush (Silicon on new brushes is no fun !!)
All that is needed now is a light and a decent camera angle
This may not be the best way of making water but its fast and cheap. The beach scene took about 20mins
For still water dont ripple as much, you can smooth the surface when its wet by gently wiping a damp finger over it.
I fit bathrooms and kitchens and believe me no liquid is better for putting on your finger to smooth it out than spit, as unpleasant as that sounds (use your own !!) Dont press hard and keep your finger damp.
RJR
PS If someone feels a need to move this to a different "How not to thread! feel free
Very nicely done how to
Very easy to follow even i could follow hat and may give it a try myself.
thanks very much
cheers Brian.W
The boss will love the "cheap part of it :!: :!:
As for the section it should be in, scenery section is good :!:
Thanks for posting the "how too" with such clear pictures. Another valuable one for the forum :!:
Ken
I could just get out the deckchairs,a nice book and a picnic and chill out on that beach!!! Very effective,and a great tutorial.When I tackle "the big one in the loft",and come to doing my sea,this will prove invaluable!
Cheers,John.B.
So choppy that Floatie Boy is going to be hard pressed to get his ball back unless it's a sea breeze :!:
The technique would be good for a weir I imagine, will the silicon work OK if in contact with either the epoxy "water" products or a varnished river?
I fancy the smooth varnish for the mill pond on Newcastle Emlyn and then something not so smooth for the weir?
Any thoughts anyone?
Pure class!
RJR
:thumbs;-)Owen
Last edit: by Silver Fox
web-cam 2.2.74.174:8081
if the lights are off no cam
