Train-Tech colour light signals
(In Topic #13899)
problem with light bleed
First my apologies to you all for not responding to my query on ground signals, that slipped down the priority list as we concentrated on nursing our cats through their final years. Trevor, I had been thinking along the lines of the w-i-t method as you suggested and I did buy a couple of the Ratio kits to see if I could do something with them. First thoughts were to use a track pin as an ‘axle’, drill hole in the disc to attach wire, wire painted matt black, to a Gem lever frame. Kevin, I have bought some colour light ground signals, for Woodside Station, which I could also use at Hooton. That project will restart when I locate the aforementioned kits in the chaos that exists below the layout…For now, another query – anybody using Train-Tech colour light signals? I use colour lights where there is insufficient access for my version of motorised semaphores. I thought I’d try Train-Tech a while back, as a change from Eckon and Absolute Aspects, finally got around to doing something with them. Thought the idea of the narrow pcb with the leds premounted was quite a good idea, but the first three aspect I’ve built suffers from quite bad bleed through of the light from the lit led to the other unlit leds
Closer inspection of another kit, the leds appear to be moulded with a deep square transparent base
…which must surely transmit some light as the base sits behind the signal front ….. also the leds themselves are not a tight fit in the signal, which can only add to the problem….
…. or is it me??? …. It quite often is….
Keith
Do I have a plan? Na, if I did I'd spend most of my time trying to remember where I put it.
– you can see that the light is transmitted into the base of the led and then on to the adjacent led. The painted red led is now unaffected, just holding the pcb between the front and back of the signal, and the green led still lit
… light bleed to the yellow, but no sign on the red. With the red led lit, holding the back on the signal
… success! I then painted the yellow and green leds, and they too showed no light bleed. This is the green with just the front of the signal balanced on the pcb
…so I reckon that’s problem solved, and now painting the bases will just become part of the assembly process. Now, with the signal reassembled
…and subject to clearance checks with the fiddle yard approach below it can it can now go at the final tunnel mouth into the loops under Woodside to provide the fat controller with the essential ‘caution’ required for running the railway. The rather untidy location board will need tidying up too.
Keith
It is the kit, as are the Eckon examples, which are my first choice. Must admit I didn’t notice any problems when I first installed the signal – it was only when I took that close-up of the signal on red I saw the bleed problem. From a distance, looks fine… but then I knew it was there, so couldn’t ignore it – ‘operational’, as opposed to ‘scenery’. It could be me, although I can’t see I’ve done anything wrong – they are so straightforward to assemble, but that said if it is me, it’s not the first time!
Incidentally have the Train-Tech signals always had the leds on a pcb?
Keith
No idea Keith. Mine were fitted by the layout's previous owner, heaven knows when. I'll have a look tomorrow and see if they're on a board or not. As I said though, I think mine are all 2 aspect but wouldn't be sure …………….………………………………………………….
Keith
Keith
Thanks for sharing your get around with the light bleed. I had never thought of doing that. I have numerous colour light signals which suffer from this. Mine are all constructed and glued now so it is something I will have to live with.
Gary
Keith
Keith
