Using polystyrene/Styrofoam for buildings .....
(In Topic #21972)
Is it any good ?
I watched a clip the other day of someone making buildings out of polystyrene - the expanded foam rather than Styrofoam extruded foam.He used a hot knife to mark out the stones but not sure what the backing for the polystyrene was. It's pretty delicate stuff but, from his clip, made some nice stone walling etc.
Has anyone used the material and if so, how difficult is it to handle, does it need coating with something to toughen it up and is it durable on a layout ?
I made these bridge supports from polystyrene, I just carved the lines with a knife. Not sure what kind of styrene it was but once I painted it with acrylic it hardened up when it dried. ( it’s a replica of mumps bridge in Oldham, it was knocked down to make way for the tram station)
Another option is the florists foam block (the grey one not the green) and once it’s painted it’s ok.
The "firm" packaging foam you mention is probably "extruded" polystyrene commonly known as "Styrofoam" (XPS) whereas the softer white (usually) stuff which results in thousands of statically charges "balls" if cut is "expanded" polystyrene (EPS). This latter EPS can also be very hard but is very easy to tell apart from XPS.
The mumps bridge I made in this thread was the grey florists foam block. It’s easy to work with and once painted it seems to have a firm finish to it.
SM SunniMix 5 PCS Foam Board Hobby Foam High Density DIY Model Material blue Sheet for Crafting, Modeling, Sculpture, diy for Crafts 30cm x 20cm x 2cm : Amazon.co.uk: Home & Kitchen
White XPS craft foam
If the smooth surface of the extruded type is gently scored and then rattle-can sprayed, the solvent etches along the score lines. I have never tried it with stonework or setts, but it gives great plowed fields.
