Signal Cabin
(In Topic #11603)
R010
The D&S needs two of these - one each end of Tawnton
so they will be built together at the same time.
I tend to agree with Marty here - I don't think it's one of Mr Wiffen's best models somehow, although I've never seen it "in the flesh" ………:roll:
If they were a light colour it would transform the look of the model.
You could always do the weather boards and the roof tiles in layers Ron…..that would give it some texture.???
Looking forward to how you approach the build.':cheers Gormo
It does look good, though.
Well, come on Ron, you're normally finished by now! :pedal
Give a bloke a chance to get his work area set up !!! plus find the card, etcI too thought that the window glazing was the culprit.
plus having sciatica is not helping…..
Ok. Tomorrow then? :shock:
:lol:
Sorry to hear the sciatica is back Sol - hope it's not as bad as last time. I have a few aches and pains but fortunately, nothing as constant (or severe) as sciatica. Do painkillers do much good or do you just have to grit your teeth until is wears off ?
Look out he`s picking up something to throw at me.???
:pathead
Gormo
Take it easy,
Bill :cool:
and then on 200gsm card
still not impressed so I have just with a thin pencil, darkened the lines between planks and I think that will do as both cabins will be 24-30" ( 60-75cm) away from the operators/
Evergreen Styrene product code : 4081 has a 2mm spacing and 4101 has a 2.5mm spacing.
Last edit: by Gary
I reckon the fine pencil line should do it, if you invoke the three foot rule.
Maybe one of each?
Bending cardboard into 90 degrees is no fun as the card can split the wrong way - thank heavens for corner elements
this photo shows where the cabin will be based on Operators viewpoint
so any minor blemish may not get noticed ( hopefully)
