Scalescenes Cargo Ship
(In Topic #10369)
Building a ship in card.
I downloaded this interesting kit when it was released and decided that it was time to take up the challenge. I must say that, so far, this has been a very interesting and enjoyable model to make. It is well-designed and every step has been easily accomplished. There are 152 separate instructions and I am currently on 64, so a bit of a way to go. Here are some photos taken at various stages of construction:First off, the bow (pointed bit at the front, for you 'land-lubbers') is constructed.
Last edit: by col.stephens
Last edit: by Gary
John, the instructions do suggest that some optional commercial fittings could be used, such as handrails.
John Wiffen has a lot to answer for
Out of interest has John given you choices about the Ship's name and port of registration (and I guess ensigns)?
The kit does allow you to choose the name for the ship and home port. There is a choice of civilian ensigns for the UK, Australia, the Netherlands, Germany and Norway. There are also four shipping line flags.
Thank you Ron and John. The completed model might feature in a dock layout. I've always had a desire to model one.
Thanks Terry…….I shall look forward to following your dock layout thread
I wondered how John would handle the detail on the stern…..I suppose he has covered his major markets although here in Vancouver you will mostly see Panama, Malta or Liberia although I guess ,despite her apparent size, she is in reality a coastal vessel
Last edit: by John Dew
The remaining hull sides have to be attached next.
The beauty of this method is that the finishes are on the paper. No painting. :cool wink
Another excellent build.
As Marty said, she looks a big beast ………..:shock: In her favour, she's fortunately an "older design" when ships had some grace about their lines rather than the ugly modern platforms only built to carry tin boxes…………….;-)
I can totally relate to the above Terry. If I had one criticism of Scalscenes it is that John's instructions dont always emphasise enough the critical importance of certain, sometimes quite obscure, components.A slight problem was encountered here as the opening for the side light on the hull has to match up with the corresponding hole in the bridge front edge. Mine didn't, so, using a scalpel, I had to remove the upper deck and bridge unit and trim the underside in an effort to lower it slightly. It also appeared to me that the lower edge of the hull would not reach the bottom of the model. I glued the top of the hull into place first, ensuring that the side light openings lined-up. I worked my way down the hull side and, much to my surprise, it actually reached, well almost, the bottom of the ship.
Regardless, you are making a splendid job of this particular model.
Kind Regards
A friend who builds lots of card ships tells me the secret is to use only enough glue to tack the plating to the ribs - dots of glue here and there rather than coating the whole rib edge and to "pre-bend" the plating so that the glue is only required to stop it falling off rather than to hold it to shape.
Ribs showing through the card hull plating on this type of structure is a common problem Terry - you should see a warship I built some time ago …………
Its not uncommon in real life with fibreglass sailboats!
