TwoboltJohn`s DCC sound video`s 7mm and 4mm
(In Topic #12095)
Hardwiring sound decoders into kit built loco`s
I have been slowly fitting DCC sound to my kit built stock since 2012. I have been lucky enough to have discovered Zimo sound decoders and consider these to be the best so far…….Most of my 4mm locomotives have been fitted with the Zimo MX648.Starting with my 7mm locos I have fitted these with the ZIMO MX645 as these are quite adequate for the modern motors that are fitted in my stock.
https://www.youtube.com/watch?v=7-EcYyc7ks8
Sound file and decoder is from Youchoos andis based on the real thing….I use the NCE Powercab.
Twobolt John
Hard-wiring - as in red/black directly to track pick-ups, orange/grey directly to motor terminals?
I discovered that there are few problems with hardwiring Zimo decoders. I am not an expert, just a confident enthusiast.
This particular model was built in 2010, way before I had considered fitting DCC sound.
The first task was to establish the ampage requirements of the modern motors I use. Mashima, Maxon, Canon and Sagami.
These draw less current than some 4mm models.
They draw less than 0.5amp working normally and often less but no more than 0.8amp when stalled.
Hence the Zimo MX645 which is rated at 1.2amp (2.5peak) plus it`s 3amp amplifier is more than adequate for my 7mm locos………….. providing there is no electrical shorting …………..
The second task, therefore is to check for potential electrical shorts…… that must count as a risk assessment in modern parlance !!!????
my locos are all metal so risk areas are :-
metal brake shoes touching the drivers
wheel guard irons touching the track
sandpipes touching the track/wheels
power pickups touching the frame etc
wheels touching the chassis frame
exposed wiring touching what it should`nt
decoders and their speakers shorting out against the model itself.
obvoiusly if the model is runnung perfectly fine before you start you are almost there………..
The third task is to adjust or insulate all risk areas………….
I always label the wires from motor and pickups………….in case I`m called away and then get mixed up !!!!
Then , as you say Nigel, follow the instructions given with every decoder…………………
red and black wires to the pickups (track)
orange and grey to the motor.
purple and purple to the speakers of your choice
( the Youchoos decoders I purchase have a stay alive capacitor already connected to the decoder )
I never solder any wires directly onto the decoder as It`s a recipe for disaster
So there you have it….. six wires from the decoder to solder up making sure the connections are insulated with heat shrink tubing.
I use these plastic cased reflex based speakers to avoid electrical shorts against the loco `s metal body
And exactly the same procedure for a re wheeled, improved coupling rods and a fitted Zimo MX648 decoder and sugar cube speaker BACHMANN 4mm RTR tank loco.
Last edit: by Twobolt
Twobolt John
So these decoders do not come with pin terminals already connected? (6, 8 or the millipede PLUX). No experience of Zimo decoders, hence the question. Just checked the 645, no plug. I never let a soldering iron anywhere near a decoder, board or wires, especially an expensive sound one. Only exception used to be the speaker wires, and now I've switched to using micro-terminals (mini-terminal blocks) and micro-2-pin connectors so that the decoder can be removed without touching the speakers (or vice versa), as it's a darn sight easier when wiring 2 or more speakers to the same decoder.
Yes they come with 6 and 8 pin plugs, which of course I cut off. Some are 12 pin.
Twobolt John
I use female wiring harnesses (6, 8, 21 pin, yet to do a PLUX pin-out), which obviate the need for hard-wiring a decoder. If it comes bare-wire I use screw terminals.
Twobolt John
I have the Dapol 08 on order and I believe it will have a Zimo sound system. I also have the Little Loco Cl 15 on order and have arranged to have my model equipped for sound - Zimo as well.
Anyhow, I completed `sounding up` my LMS shunter this week. ( I sold some 4mm stock to fund it)
Zimo again and a J94 soundfile from Digitrains with Paul Chetter`s Multidrive sounds.
https://www.youtube.com/watch?v=ylO_Pd0pzj4
But to restore the equilibrium I must add my favourite 7mm build and loco……….
GWR…… Dukedog….. from a Javelin kit with Youchoos sounds from Preserved 9017………………
Twobolt John
Here's a short video of my ProtoDrive sound project for ZIMO MX644D as required for the Dapol 0 Gauge 08.
(PeterM, if you have your ears on, you can reveal what you've had on you 08 for some time now, LOL)
Kind regards,
Paul
:thumbs :thumbs ;-) :cool:
Owen
web-cam 2.2.74.174:8081
if the lights are off no cam
Owen,very nice ,I like the radio voice,very authentic,,
Owen
Thanks for the appreciative words.
It should be authentic, this shunt actually happened whilst I was recording the loco.
Not as local to you as you may think from the accent - it was at Eastleigh yard.
Kind regards,
Paul
