Low Relief Brick Terraced Houses
(In Topic #384)
Bob(K)
I've found these useful for my layout, but needed to leave the bay windows out, to match typical terraces (Ex National Coal Board) found locally.
Like you, I intend to replace the chimney pots with Wills ones and re-roof by tiling over the card roof fitted.
I also intend to provide gutters & down pipes, finishing off with some weathering using Artist's Pastels.
Will have to look at these Wills chimney pots as my attempts at the Metcalfe one's leaves a lot to be desired :roll:
Have wonderd about these low relief kits and you could maybe answer a question I have. If, as you say, you are going to put them against your backscene, does that mean you have to paint the rest of the house ie. the reamining gable wall, onto the backscene? I suppose you could disguise it with a tree or something. :? :?
Les
Devon Junction
Kernow Junction
Kernow Junction
MikeC said
Very smartly done, Bob. Any plans to light them?
No, I am going to keep it simple. They will just sit in the background - for the moment.
Bob(K)
Les
Devon Junction
Kernow Junction
Kernow Junction
Brian(G)
Les said
They look good Bob. :)
Les
If you have a look at my backscene thread (Backscenes for non-artists), you will see another idea for blending in low relief buildings against the background Les.
In my case, I've used layers of backscene papers to give the illusion of depth and treated the low relief buildings as part of the backscene. (Well they are really) The eye is then fooled into thinking that the low relief structure is a full building.
Have a look at my link to see what I mean, you'll find the first photo of a low relief terrace halfway down the initial post, which then goes into some detail on how I built it up.
Here's the link:-
http://yourmodelrailway.com/viewtopic.php?t=162&start=0&postdays=0&postorder=asc&highlight=
Put it down to age I'm afraid but I had forgotten just how good that post is, in fact worse still I had forgotten the post altogether. Thanks for reminding me. :oops: It really does answer my question in a very effective way.
I hope I forgot it because I was nowhere near that stage of work on my layout so to be sure I have copied it, saved it as a Word file AND printed it out. :wink:
Thanks again,
Les
Devon Junction
Kernow Junction
Kernow Junction
anyone know how they do that?
I didn't think the Metcalfe roll-up chimbly pots were too clever, but I've found that if you use comparatively generous amount of PVA, wind on the tip of a cocktail stick, you end up with a slightly glazed looking clay pot, soft enough to 'twiddle' on the stick with your finger nail against the end to give this [below] appearance, [ a scratchbuilt LR bombed terrace circa 1900], go on, have another go!
Depending on how you cut your strip of paper, and what you 'twirl' them on, the possibilities could be endless, and you can spend the money on important things like Scottish Laughing Water :cheers
PS I know the chimneys should be laid-up in plain bond, but I hadn't got any at the time, sorry!
