Building Elvenhome, my first N Gauge layout
(In Topic #13067)
It is a fictional place with the names for almost everything taken from the works fo JRR Tolkien, principally Lord of the Rings. The main station is called Weathertop with three other stations, Grey Havens, Sharky's End, and eventually High Elven. It is DCC but with DC control of point motors and lights. It took about a year for me to source and have supplied the baseboards (living in a 3rd floor flat I have very little scope for major woodworking) for my L shaped layout.
My wife also suggested that I should document the build of my layout on YouTube. I was not at all sure about doing that but I decided to give it a try and I have, to my astonishment, found it great fun and a spur to getting on with things to be able to show in my regular updates. I will post a link to the latest video shortly after posting this introductory messages
I have been astonished by the range of skills that you need to master. I have enjoyed the challenge of learning them and applying them. I am particularly enjoying scratch building things for the layout, mainly so far from card, so that I have things that are unique to my layout. Above all else it has proved, and is proving to be great fun. I hope you will enjoy the updates to the layout as I record them here.
[/yt]
Here is the link to my latest video with me completing the gardens for the Gardener and Sexton to St Eldar's Church at Grey Havens. I also have a first go at building a hillside.
Last edit: by breakage
Very nice. Do you have the dimensions?
Thanks. Have to convert to imperial, this is the U.S. Note the absence of the V.
Last edit: by Barchester
Hi Nigel,Hi Stephen,
Multiply the metric measure by 39.37 will give you the size in inches. You can do feet from there! There are a lot of people younger than myself who cannot work in imperial in this now metric country
900mm is a little over 35"
2800mm is about 9ft 2"
1900mm is about 6'3"
The trick is to work in metric rather than try to convert as I found when the changeover occurred here in mid 74. I could not believe the recalcitrance of people I met in America 2.5 years after that who could not get their heads around the metric system and subsequently dumped the idea.
Hope this helps!
Regards from Australia
Im sure all of us have damaged or broken things in error at some point.
At least it was only a model and you didnt burn a hole in your leg or set the house on fire Stephen.
Indeed so Brian. It wil serve as a good lesson for the future and all ended well with three sound fitted Castles on the layout 😄
Stephen
Look forward to seeing more!
Stephen
