Cobalt Point Motors
(In Topic #11075)
versus Wire in the Tube
Hi All I am really torn between Wire in the Tube with SPDT slide switches(being able to change the polarity), and going to the bother of Wiring up point motors especially the Cobalt, 40 odd years ago Hammant and Morgan were the best "IMHO" available as I could wire my "Home made colour light (with route indicator) to the point motor. Once the route was set to leave the mainline with a green signal, At least it would be better than the model railway "Equivalent of S P A D S ", as often seen on youtube. ATB Kevin
wire in the tube
Tortoise/ cobalt
solenoid units like Peco
Caboose Hobbies ground throws will switch the polarity. Simple lever beside the points. Fast Tracks do a wire system switch unit with polarity switching built in. This is low technology (wood!).
Apologies - Caboose Industries point lever, Sharp Models in the UK carries them. Fast Tracks is a Canadian company, their Bullfrog range of hand controlled switch mechanisms is excellent. It comes with an SPDT, one more can be added. If you DIY don't use bicycle spokes, use wire used in model plane control systems. Handlaidtracks.com.
Living in North America and modeling UK means extra research and a lot of mail order from the UK. A lot of excellent "HO" items are out there that can be used in OO. Canadian items are a steal given the exchange rate.
Ee by gum lad, it's ebay or nowt. Or Amazon (my wife has a prime account, free shipping on most things and order today, here tomorrow).
No offence taken. The point is that there really are a lot of good things out there that most people in the UK are unaware of. The Fast Tracks products are just one example. For most modelers in North America mail order is the rule not the exception. For UK outline modelers it often means from the UK.
And it might be that easy, but, I'm yet to be convinced. Now if the £ was as strong now as it once was? and I was still drawing a salary, instead of being a pensioner things might be different. ATB. Kevin
How about this as a manual control:
Blue Point switch machine turnout controller, No electrickery or motor, designed for rod control. $10.95. There is a DPDT snap-action toggle switch inside to change frog polarity, etc., and which holds the switch rails against the running rails. Not sure about UK suppliers.
Pete.
A-line, and they do not export. Micromark has them on special at this price. Cheaper by 5 and even better by 10. Last I heard they do international mail order. Walthers has them at $13.95. Typical. List is $12.95. Lot smaller than a Tortoise.
Any issues PM me and I'll see what I can do.
