hornby motor replacement
#236748 (In Topic #13079)
C.D motors
this loco started off as a C.D. test chassis then i found two HST bodies
Which C D motor did you use ? the cd drawer motor ?and how does it run ?   looks like a fun project and certainly made me look twice !
just bought them on e-bay - simple conversion go to youtube for a tutorial " replacing hornby motors"
so i can remove the motor anytime i copied the hornby faceplate - then cut a hole then fitted it to the chassis - pushed the motor into place then run super glue round the front the - gear from the old motor will be too big for the new shaft but a guy on e-bay sells gears that will push on
forgot to mention - there is a raised boss on the back of the new motor and after removing the brass bush you need to open up the hole so the motor will locate in the chassis - hope this helps
Hi Ian,
what a nifty idea - I have a few old CD players somewhere in the garage so I will add this conversion to my list of "TODO" projects.
Is this the video you were referring to ?
Notmutley
Hi Ian,
What is the voltage range? Many CD motors are 5.9-6v or less.
