Weathering the tracks with TAMIYA TS1
(In Topic #13271)
I'm thinking about weathering the tracks (Peco & Hornby) with TAMIYA TS1 red brown. All your thoughts, advices and comments will be very appreciate. Thanks.
Sorry if this question has been asked too many times before… :oops:
Nice base color. Not optimal for metal, it uses solvent compatible with plastic models. GIve the track a good wash with hot water and dishwashing liquid using a soft brush, rinse well afterwards. The rails and ties usually have an oily surface from the manufacturing process.
Red oxide primer (automobile repair and iron primer) is a good alternative and a lot less expensive, use water based acrylic rust afterwards. Or you can avoid the aerosol paint and the solvents and go straight to acrylics.
Flexible track becomes very stiff after spraying.
Martin
Good colour choice… I actually used as part of the railway renovation for the St Agnes Railway the ACRYLIC version of that colour and applied it by hand brushing. That idea has worked fine for me!
Cheers from Australia
Bon app,
