Electrics. DCC
(In Topic #12339)
Decoder fitting
Hi All I have just purchased a new Bachmann loco , after giving it countless runs up and down a plank I had enough ( true I could have followed the suggestion and made up a circle of track) . Anyway I now had the Decoder and I wanted to fit it. I had taken the shell off the chassis, removed the blanking plate. The E-Z Command 90degree?6pin DCC Decoder was recommended for the 64xx Class 0-6-0 Pannier tank Loco. Fit Decoder , screw in the screws, and away, nothing , check all okay with the Powercab, nothing, back to the "work tray" sitting there was the blessed Decoder , start again, but this time I saw the blessed Decoder do a bunk, eventually I did manage to fit the Decoder and get the loco running. Perhaps I will get a circle of track( With a Large Radius) for future "Running In". But this blessed Decoder , as per Bachmann recommending another Decoder for another Loco I think I had better ask YMRC Forum All the best. Kevin
http://yourmodelrailway.net/view_topic.php?id=12700&forum_id=16#p223529
Just had a look at the chassis design of the 64xx. I think I would have got rid of all that RF gubbins and used a wired 6-pin decoder.(Actually I would probably have ripped the whole lot out and hard-wired an 8-socket wiring harness).
It shouldn't be loose. Those pins are supposed to be a tight friction fit in the sockets.
You need a horizontal 6 pin N-scale decoder, not a right-angle one.
Yes you have been misled. It will not fit. NFFIP. Send it back after complaining and getting written conformation that all moneys including postage will be immediately sent on receipt of goods or credited to your card.
Page 46 Using programming track then option 1, work your way through that part until you get to address on page 48.
Sometimes you need someone to show you physically
nce power cab setup
for more
Powercab at the ready following the instructions , but then my Powercab screen read different from that on the video.
What had gone wrong? I asked myself, was it my button finger? Or what? :???: try an already set Loco ? That works fine try again still the same, I will have another go soon. All the best. Kevin
Avoid any confusion and select "no" (enter) when asked to select the short address, "yes" (1) when asked to select the long address. That video is a bit misleading as not all operating systems have the same short number capacity (and it should be 127 or less anyway) or long number capacity. I avoid short addresses at all times and use 3 or 4 numbers in the long address, as I have to switch between NCE and Digitrax systems.
See https://sites.google.com/site/markgurries/home/technical-discussions/decoder-addressing/address-confusion for the differences.
As usual, if in doubt read the manual.
All the best. Kevin
All the best. Kevin
Here we go then.
If the locomotive still has the factory ID (3) you will see this on the programming track:
Press Prog/Esc (4 times)
Until this screen comes up.
Press enter. This screen comes up. We want 1 - STD.
Press 1 and the two following screens come up. First is the decoder manufacturer (101 - Bachmann Trains), press Enter and the second screen is the decoder version.
Press Enter, and now we're down to business.
Press 1. This then comes up:
Press Enter. This then comes up:
Press Enter (in other words don't activate the Short Address). The next screen is where we want to be:
Type in the number you want - ignore the 003, it will be over-written. In my case I want 0050.
Press enter. The next screen comes up:
Press 1 to activate long the address. The next screen comes up:
Enter No. Do not press 1 unless you want to alter the way the locomotive runs*, which means reading the decoder manual. Then press Prog/Esc a few times and press the Select Loco button. I will see 050. And away we go.
My 40 tonner only gets going at setting 20, so I will adjust this with the Start Voltage setting until it starts to trundle along at setting 1. Plus add some momentum and decleration so there is a slight delay in starting and in stopping. Just like the real thing.
All this is in the manual that came with the unit. Pages 46 on. NCE is pretty forgiving, if in doubt just keep pressing Prog/Esc. NCE also recommends that you keep the short address as 3 and the long address as what you want it to be.
*You pressed 1 instead of enter when you started seeing things like Start Voltage.
Save
