Unusual stone cottages
(In Topic #10432)
Purbeck stone in Corfe Castle village
This little terrace has intrigued me for many years; I'm contemplating a model in N gauge, I've got some stone plasticard and painted it fairly near correct. I doubt the model will be anywhere near 100% accurate , I just hope it can be close enough to be recognised by anybody that knows the original.
Might be an interesting challenge, anybody fancy a go? Marty, Gormo?
I've often wondered what the inside is like, and why the external steps, is the upper floor a separate dwelling or is it instead of an internal staircase? (bit chilly going to bed on a cold winters night!) Is it 4 or more dwelings? Has a door been blocked in between the windows and downpipe left of centre?
Left hand end has a window for upper floor, but is that another window or a door below? The number of chimneys suggests 6 rooms with fires, unless there are more chimneys on the rear.
Note the way the gutter passes across the upstairs windows; the roof looks like it will need some fiddly work, alternate rows being wide, narrow wide narrow, plus it's not slate nor concrete, it's more Purbeck stone!
I had a rough go at sizing things, if one assumes the doors about 6'6"', then the height to the eaves is about 13' 6", difficult to get accurate figures with it not being square to the camera.
https://www.google.co.uk/maps/@50.6360351,-2.0546625,3a,75y,62.71h,91.02t/data=!3m4!1e1!3m2!1sXz8H3E4d8VKO1euSJdFtOg!2e0
There are 18 courses of brick on the centre chimney, what would that be in terms of height in feet?
If you follow the lane at the right it leads to a playing field with the Swanage railway running alongside.
I'd guess the top floor is one house - maybe 2 if there's another door round the back. Ground floor seems to be at least 2 houses. If you look at your Google image of the front, there's a door catch on each of the double panels either side of the external steps - the left hand one even has a sign in the window reading "No 2, Jubilee House" The stone block inscription on the right hand end, which I can't see too well, either says "Jubilee House Nos 1 & 2" or "Jubilee House, 1622 (or 1822)" I think they're older than 1822………..
An interesting model to attempt - one for Dooferdog maybe …………………:roll:
Jubilee House, Corfe Castle, Dorset
