NCE Powercab
(In Topic #14008)
I have done this before, but, I have had too many bumps on my head
Hi All You won’t believe this? then again you may, believe it as I have aired my problems before. It is how to get my NCE powercab to control my Locos. And I am certain that I have previously asked this same question . I am so eager to catch up with the simple task of running my Locos, it maybe just the dirty rails, but then again I had a shunter running up and down trying some part built kits without any trouble. First of all how many different Locos can I control with the Powercab, and I am not bothered with the short address, unless it is necessary, I would prefer to use the long address, to begin I have to plug it all in, then press the programme escape four times followed by enter , then I get mixed up? Any help would be appreciated. Best wishes Kevin
Hi All You won’t believe this? then again you may, believe it as I have aired my problems before………………………
I don't recall you asking any questions before Kevin - have I missed something ……………………. :roll: :roll: :roll:
I don't have the Powercab myself but I wonder why you want to use long addresses - it's not difficult but does very slightly complicate things. I normally use the last 2 digits of the loco number as the address, only resorting to long addresses if I have 2 locos with the same last 2 digits …………
I'm sure a Powercab user will be along shortly to guide you through it. :cheers
Ditto Peters response Kevin, someone who KNOWS will be along shortly (Hopefully) :cool wink
Oh and also clean the wheels as well as the track!!
B
I'll look for an online link for you bud :thumbs
https://www.dccconcepts.com/manual/nce-owners-manual-powercab-handset/nce-powercab-manual-v1-65/
There you go Kevin
The Power Cab has the ability to store 6 addresses if you have the latest version.
Re the loco address - that is stored in the decoder once you have programmed it & if you had set the address before & run the loco, it should still be there.
Make sure you only have one loco/unit on the track when programming.
Press Prog/esc button the 4.
To go through the sort of NCE Wizard, press 1.
Press enter to acknowledge each of the initial readings of the decoder manufacturer code and version number.
That should lead you step by step through programming the loco addresses and other parameters you might wish to change.
* If you have the LED at the bottom, the correct side will be the left socket (I prefer the LED on top so the leads don't obscure it, so "correct" on mine is the right socket).
Answers on a postcard :thumbs
I'm trying to help here but pretty much swimming in the dark as I've only ever USED the NCE once, very briefly and that was parrot fashion, under instruction so I never really got a handle on it.
I take it there is a way of switching from programming to operation and as Ron mentions, a way of recalling the last 7 stored locos ?
I'm swimming against the tide wi me feet tied together here bud
In order to eliminate variables, which is the essence of fault finding, only use the loco which was last working in you previous running session, as that one reasonably should still work. We simply don't know for certain which other of your locos also work yet, so leave them be for now.
Then try again tomorrow. Start with just trying to run that last loco you last ran and do everything carefully and slowly, just as Ron and Jeff said and it would be an excellent idea to write down exactly what you do, missing nothing out and then post your results and then someone familiar with Powercab can offer further advice.
Take it easy, have some tea and sleep well.
Tomorrow is indeed a new day.
That section seams to be about programming a loco for the first time ? OR re programming it ?
Looking at the picture of the handset what does recall loco do ? Or select loco ? Isnt THIS what you need to do to recall on of the possible 7 locos storedcin memory ? Or to enter the number for one NOT in memory ?
What am I missing ?
