Diesel loco with sound
#245129 (In Topic #13533)
How do I play all the sounds including start up
Hi All.  I have some diesel Locos with sound, but I cannot play all the start up sounds like priming and the compressor. And with the NCE POWERCAB how do I get to the higher numbers? Is it Something to do with the “ Shift Key?   Best wishes Kevin
Ron will be the best person to answer that Kevin he is an NCE user does the manual you have not tell you?
Hi Brian. Thank you. The manual (  probably ) does tell me , and I can read, but, I must be missing something .Best wishes Kevin
I'm a long-time NCE user as well.
Press option once gives you 13-19,  just press the number you want (3-9). 10 is automatically added.
Press option twice gives you 21-28.
Prog/escape returns you to 1-12.
Important: Make sure the option key is programmed to 122 using cab setup. The default value is 94 (brake), change it to 122 (extended function). See pages 18-19 of the manual. Follow the instructions.
Hi Nigel.  Thank you for your reply. I knew that I was going wrong? But, didn’t know where I was going wrong.I am pleased that you mention the manual. I have a problem with my fingers at the time.  And pressing buttons is very awkward, using my iPad is bad enough when I clumsily land on the next / wrong key at the same time.                    Best wishes Kevin
Nigel's solution is also what I suggest: I program all the cabs' Option buttons to 122 as it makes using those higher functions much easier.
As you (Kevin) surmised, there are other key shortcuts/combinations that work as well, but this solution works better for many of us.
Hi Jeff. Thank you for your reply. Sometimes DCC like a lot of other stuff goes right over my head :mutley:mutley:mutley   But I hope to look into that as soon as possible.  Best wishes Kevin
