Removable building with ballast right up to it - station roof
(In Topic #9008)
I would like to keep the building removable so that I can access the platform and track for maintenance / cleaning / adding more detail etc in future. However, the wall is irregularly shaped at the base as there are abutments coming out of it to hold the bases of the arches. I want the ballast to go right up to the edge of the walls. I don't know how to do this and keep them removable.
I thought I may just blu-tack the roof onto the arch supports but with less than 2cm between each arch, cleaning the track will still be a pain. I could glue only 4 arches and blu-tack the rest, but this will be a pain to do and to get looking right.
Has anyone else achieved anything similar?
Base of station wall - how to ballast around this and keep it removable?
So, remove the station and feed a 'barrier' strip of greaseproof paper that is well higher than the ballast line, or even strips cut from a thin plastic bag, replace the station then ballast right up to the walls and if you use watered down PVA to fix the ballast, this will not stick to the plastic barrier strip.
Give it plenty of time to dry, then ease the station away from the surrounding ballast, remove the barrier strip away from around the base of the building then it should fit snugly back into place between the ballast.
Hope this helps.
Allan.
Looking at the wall itself, it appears to have a wider baseline which looks to me like a natural dividing line. Could you cut the wall there, ballast up to the bases and lift the wall from that slightly higher point? That would still allow some room for your hands to get in.
Last edit: by SRman
That's just what I did with my engine shed, but took the precaution of sealing the bottom layer of my [card] building to prevent any leakage of water/pva from soaking up the card. I used Lidl W5 water proofer spray squirted into the lid and painted liberally around the lower 1/2". It dries matt and transparent. The 'contained' pva soaked ballast took ages to dry [48 + hours]I had a similar problem and got around it by wrapping the building in cling film before ballasting
Good luck,
Cutting along the plinth would work too, but the opposite wall has 16 floor-to-almost-top arches in it and would be an equal pain getting them all aligned.
I think I will go with the cling-film and sealed bottom approach. That had simply not occurred to me.
Thank you everyone. When the time comes, I will post updates here.
You could always get some double sided tape, cut it to fit in the gaps and stick it down, remove the top layer from the tape and then lay your ballast. When you pick up the shed the appropriate gaps will be there to relocate it. You may have to tidy up the excess the first time you take it out but after that it should be ok.
Last edit: by Kevr
'Kev
Now the really hard part - being patient for a couple of days while the glue dries!
Ballasting in progress:
It came away from the cling film perfectly, and none of it stuck where it shouldn't have done. A bit of cleaning up to do and one or two spots where there's a gap appeared or the ballast is the wrong height, but I am thrilled with the result.
It may seem like a small thing, but I would never have managed this without your suggestions - thank you very much indeed!
That means I have to start on the remaining 17 roof supports now :(
The walls were scratchbuilt. They're the length of four of the Scalescenes' modules to keep the proportions and arch spacing the same.
The Scalescenes roof is designed to sit at platform level, so with mine being an island platform, I needed to make the walls higher, hence the nubs for the supports to sit on. The arches on the nearer wall were cut out from the Scalescenes window arch templates, but taken right to ground level.
I drew a template in Microsoft Visio and printed it out full size, stuck onto card etc in the Scalescenes way.
I've added five grimy windows at the back wall, which will be ground level. Ground level raises behind the station, so no windows. These were made from the Scalescenes windows templates, and printed onto transparency using their grimy windows.
Here's a more overall shot:
Nice work. I guess patience pays off afterall ! ;-);-)
The templates come as part of the Scalescenes 'Arches and Windows' download, on the "Scratchbuilders Yard" section of the Scalescenes website:
http://scalescenes.com/products/TX00-Arches-and-Windows
If you click the 'preview arch styles and instructions' link, you will see an image of the template in use.
You just print it onto paper, stick it to heavy card, cut out, and there you go.
I just marked the centre points of where I wanted each arch, drew around the template and then cut it right to the bottom.
Hope that helps! :)
Mike.
