Sealing baseboards
(In Topic #9202)
My plans for baseboards when I build my next layout (whenever that is :roll:) are as follows:
a: tops to be very good both sides 3/8" ply (1/2" is too heavy and 1/4" is too wimbly)
b: ends to be 4" x 1/2" birch ply (to connect with adjacent baseboards using C&L steel dowels)
c: sides to be bog standard 4" x 1/2 ply (the stuff that's full of filler and thus light - it only has to resist bending).
I've had the wood for ages, got it cut at the lumber merchant (I have a phobia about power saws :shock:)
Last edit: by Brossard
I was looking at 12 mm ply but as you say, probably too heavy, maybe nearer 9 mm would do.
I haven't bought the ply yet so no problem. My " shed builder" said he would pick it up for me from the merchants as I don't have a van at my disposal. He'll also get it cheaper
I'm using 6mm MDF and gave the top a coat of grey primer/undercoat for the same reasons Spurno has outlined.
Not using cork though, as the track is going straight on the board, so if I miss bits when doing the scenery the grey showing through won't be quite as obvious.
(At least, that's the theory)
When you get onto track laying, keep that sealer handy for painting the edges of the baseboard where you need to cut/drill holes for your Cobalt point motors. As has been stated, don't forget to paint all edges, especially with ply as that is probably the area where moisture will do more damage. As you have stated, your boards will be completely covered with cork, don't think for one moment that the cork, secured PVA or Copydex will 'waterproof' the top of the baseboard.
Tip, use a Tile glue spatula to spred PVA or Copydex evenly on your baseboard. Roll cork on from one end of the baseboard, rolling a piece of dowel or a rolling pin to help level out. I had used several albums (vinyl, not cds) to weigh down for 24 hours.
I'll seal the baseboards completely before laying the cork on top. I'll try and make sure that I don't make the boards to tight a fit, leaving a fraction for expansion as well.
I've seen the spreaders in my DIY store so I think I'll invest in one this weekend. I'll see how far I get this weekend. I've also booked Monday off to give me three days to get in about it. Baseboards, sealing and possibly first fix of the 240 volt mains electrics. We'll see.
Cheers again.
Can you clarify that on top of the baseboard goes a layer of varnish, then a layer of paint, then the cork?
Thanks
Tom
Tom
Pete.
The top of my baseboard is covered with Daler board, will varnish be ok to use on this?
Tom
Unless you live in an extremely humid area then ply really doesn't need it, at most just the edges. though mdf and sundela do need full coverage. if your layout is in a house your central Heating will do the job without painting.
White paint is definitely a better idea beneath to help seeing what you are doing..
Generally thinner cheaper varnishes have more thinner in them as its cheaper than the "body" of paint or varnish.
You have to look at the can to see whether thinner / white spirit or water is required…
My comment to primers + undercoats + top coats, is you are not doing a exterior grade door, or my boat for which I would do the above with a light sanding between. ( and probably more top coats)
You are only sealing the board to prevent moisture getting in, the underside and top of a model railway which will never be seen again.
If you haven't already bought any of the above, just topcoat thinned for the first layer, followed by a top coat second layer.
Ply will happily accept a thinned top coat to soak in, I'm talking of normal exterior or gloss paint, using a "one coat" thinned is defeating the object of the stuff they put in the tin..
if you get a nice smooth shiny gloss on the top you are going to have difficulty getting, all the layers of railway scenics to stick!!!
Last edit: by The Q
Best wishes Kevin
