Which way to fit a sound decoder in a Bachmann 08
(In Topic #11405)
Bachmann 08 and Zimo MX648R Sound decoder
As some of you are aware, not that long ago I purchased Paul Chetter's new 08 sound profile from Digitrains. This comes on the Zimo MX648R decoder to fit the Bachmann 08. With no instructions in the box, I would like to know which way round does the decoder plug fit the socket ??Here is a pic of the plug in the front of the 08 with the decoder plug beside it.
I'm unsure whether the red and orange wired end should be at the bottom (as shown) or at the top of the socket.
Any assistance would be greatly appreciated as I don't won't to ruin $220.00 (£104.00) worth of decoder/speaker… :shock:
If there is no marking on the socket, you won't break anything by plugging it in upside down. The locomotive will move in reverse when forward is selected, and vice versa. Lights will not work, although for the Hornby and Bachmann 08/09 shunters, no lights are fitted, so you won't be able to use that as an indicator for correct mounting.
If you are still worried about using the sound decoder, try a 'normal' decoder first, noting which way up the orange/red end is when motion occurs in the correct direction for that selected with the controller.
Last edit: by SRman
I have sent Paul an email earlier today, but that would have been 2am in the morning, in UK time ! ;-)
I've answered your email earlier.
I also posted a response on here, agreeing with what Jeff posted, but it has not appeared.
Kind regards,
Paul
Keith.
Keith.
This is what Paul had to say :
Hi Gary,
I can’t recall which way the plug is orientated. For my Hornby Magazine article, I removed it and the mounting lug to make room for the decoder, cube speaker and stay-alive capacitor etc, The track pick up strips and motor wires are easily accessible.
If you wish to retain the plug, you will need to put the speaker in the cab. That’s a pretty good solution, but you will need to create a channel in the top of the ballast weight (remove retaining screw for access) to allow the (purple) speaker wires to pass into the cab. Remember to insulate the speaker terminals/backplate.
If you have no plans to fit lighting, the orientation of the 8 pin socket is not so important. It is designed to be ‘safe’ either way round, that’s why the track pick up pins are diagonally opposite. The decoder and motor will still operate, as will the sound. If any of the lighting pins are in use, they must be the correct way around, but are still electrically safe if you get it wrong – if the lights don’t work, turn the plug around!
There are no such connections to worry about in the Bachmann 08.
Sometimes you will see a dot or a number 1 printed next to one of the connectors in the socket. This denotes pin No1 aka orange wire.
Good luck with your project.
Kind regards,
Paul.
Ok, there you have it. Paul has been very helpful with this matter/concern. He has even given greater help in which direction I should run the speaker wires and extra insulation, which I personally would not have given any thought. As Max stated, Paul is a busy man with creating sound profiles, writing articles on installation of sound decoders and answering any questions put to him. Not to mention how many different locos he has installed sound and trying to remember how he had done them all.
Thanks again to Paul and anyone who had responded to my original question.
Last edit: by Gary
Code
toto wrote: ...
I understand fully that different manufacturers do things their own way. That is one of the reasons that I don't like the idea of the suck it and see approach.
Is it not even remotely possible that by plugging it in on say a certain model of Heljan or Dapol that it could fry the chip. I don't think it's unreasonable to assume that it's possible.
TotoTom, unfortunately if manufacturers do not label the socket with Pin 1, unless the wiring colours are based on the decoders standards, it is a suck & see process. Even Bachmann have been known to reverse wiring. Plugging them in the wrong way will not hurt the decoder
In the early Hornby decoders days, they were blowing up on Heljan locos as Heljan took more current than the Hornby decoder allowed. Even Simon Kohler when he was involved with Hornby, tested Hornby decoders with Heljan and did report in Model Rail Express site, not to use the decoders of the time with Heljan.
To find out what decoders are suitable for locos. many people find out the stall current of the loco
http://www.dccwiki.com/Stall_Current
http://mrdccu.com/curriculum/stall.html
then once the current is known, then one can select the correct decoder by looking into the data associated with the decoder
example http://www.tcsdcc.com/Customer_Content/Literature/Decoders/HO_Scale/DP-Series/DP2XUKBEMFWEB.pdf
Unless the socket is wired wrongly (very unlikely!), no harm will come to any decoder. If the socket is wired wrongly, then the decoder is probably going to be history even if it is inserted the correct way round.
It's good practice to check with a cheap decoder first. Plus all that RF suppression gear is probably not required, ZIMO I think recommend binning it. You get a lot more space and you know the wiring is correct. Hard wire or use an 8 socket harness.
:shock: GULP ! :shock:
I think I'll take the advice and throw in a cheaper decoder to be on the safe side.
Last edit: by Gary
The colour code is straight forward.
RED = right rail
BLACK = left rail
ORANGE = motor (+)
GREY = motor (-)
WHITE = headlight
YELLOW = rear light
GREEN = Aux 1
PURPLE = Aux 2
BLUE = Common (+) for lights
You should be able to match them with the colours on the plug.
I had picked up a cheap Hornby decoder earlier today, so I can test the correct positioning of the plug. But, funny how I found the tutorial after I purchased the decoder ! I'm sure I can use it elsewhere, and yes before anyone says something, I do know what they say about Hornby decoders… :shock:
Cheeers, Gary.
