Vitrains Class 47
(In Topic #11325)
Where to put the speaker
Has anyone fitted a sound decoder to a Vitrains class 47? Where is the best place to put the speaker? Had a look inside and space is limited. Thanks in advance Andy
No, but looking at the chassis there are some options.
1. Bin the circuit board, replace with hard-wired decoder, put speaker where the old circuit board went.
2. As above, position rectangular speaker over gear tower (looks to be plenty of room), in fact you could put one either end. Build up support platform with styrene strip.
3. Keep the board, speaker(s) over gear towers. This keeps the light functions.
You could probably get a thin speaker in without modification with it sitting on the board. Seal the back with adhesive foam tape.
See for a DCC non-sound and the space available over the gear towers:
https://clarahost.clara.net/www.bromsgrovemodels.co.uk/vitrains37dccinstr.htm
Kind regards,
Paul
Andy
Thank you for your explanation, I can see now what you have done.
Interesting use of the TTS decoder. How do you find it works in this loco and with this speaker?
Have you turned the volume down at all?
Kind regards,
Paul
regards
Andy
