Monthly project - September
#127374 (In Topic #6687)
A Grotty Washroom - Stu's words !!
Right, over to any member to start this off for September.
I will add the second line of the project description when you let me know.
Do I have to get the big stick or carrot out to inspire someone to do a monthly project???
  I realy like the idea sol, but my modelling is too slow to get anything worth looking at in one month.:cry:
I'm building another (my 4th) entry for the Model Rail / other forum competition. This is a simple diorama of a grotty washroom (long story…).
I'm hoping to start tonight, so if required I can post progress photos and how-to notes.
The encouragement is for others to have a go at something completely different to what you'd normally model, in a very small space, just to stretch yourself.
Stu
Now done - that is the second line of the description.
Thanks Stu
Oo-er, what have I done….
Ok, from my point of view this is intended to be a very quick build - even by my standards - I hope to start and finish this tonight, in a single modelling session of about 4 hours…
To help with this, I needed a parts list, so I know what to use where and so I can plan in my head in non-modelling time how I'll tackle each bit.
So :
Parts checklist :
Basic wall & floors - foam board
Wooden floor - lollipop sticks
Lower walls - plasticard planking
Upper walls - card
Dado rail - coffee stirrers
Mirror
Tiles around mirror - plasticard tiles
Door - card
Toilet cubicle - card
Toilet door - yet more card
Toilet
Header tank - fabricate from plastic sheet
Header tank brackets - 'T' plastic strut
Sink
Sink supports / side towel rail - paper clips
Pipes - various plastic tubes
Watercolours & acrylics for making everything grotty
The toilet & sink are the only items I've pre-bought, from a wonderful website called Elf Miniatures
These are my collected thoughts so far (gives an insight into how my tangental brain works…) :
Sub-Floor - two layers of foam board, with foam board spacers to make a sandwich construction.
Sub-Walls - foam board - with these glued to the floor and each other I'll get a three sided (1/2 cube) box, which should be rigid enough.
Floor - lollipop sticks, rounded ends cut off, laid side by side, with one or two having joints. These may need sanding down after glueing.
Lower Walls - Clad in plasticard planking - should just need painting, but could distress lower edge as rotten wood, skirting board ?
Upper walls - either use a piece of card, or just the foamboard itself - need to add damp patches, flaking paint - needs more thought how…
Dado rail - could use coffee stirrers (depends on scale ) or plastic rod
Door - 4 panel door - thin card cut out for each panel, if possible multiple layers to give more detailed relief - door handle - use bead, door lock - not sure, but should be broken (brass tube ?)
Cubicle wall - card, with short legs to leave gap to floor - legs from old plastic sprue - possibly have hole/s in
Cubicle door - off hinges, leaning against cubicle wall
Header tank - either make out of plastcard, or find a suitable small box. Needs wire / lever for 'chain', feed and drain pipes. Supports made from 'T' plastic strut, with wood battens on the wall from split coffee stirrers
Toilet - needs waste pipe (large dia plastic tube)
Sink - side supports / towel rail from paper clips - painted white
This is not a complete list, nor necessarily one I'll stick to, but I find it helps me to visualise each element of the project, so when I come to the build itself I can just get on with it. Obviously, practical differences with what I'd imagined cause deviation in this plan, but it seems to work for me…
Ok, here we go - 9.10pm.
First thing is to work out some dimensions…
A real toilet is approx 15" from floor to seat - the model version is 1.5" = i.e. a very convenient 1:10 ratio.
So, the the door at 2'6" (30") will be 3" across and at 6'6" (78") 7.8" high.
This gives a rough overall size of 8" x 5.5".
Now to cut the foamboard to fit.
Last edit: by Stubby47
Does anyone manufacture model cottagers?
http://dddioramas.webs.com/
11 + 2 = 12 + 1
Probably…..
Wooden floor now laid :
These are lollipop sticks (£1.00 for about 60) with the ends trimmed off and then laid to alternative floor edges, then smaller pieces cut to fit the gaps.
The floor, walls and pan have had their first coat of grot.
The walls and floor are now stuck together :
The sink has been installed and the cubicle partition is being assessed for size.
Lookin' good, Stu.  :thumbs   Are you planning to have some graffiti?
Thanks Max. Yes, graffiti is planned, using a fine pen. I also want to add phones numbers ("for a good time call…") of either football clubs (eg Man Utd) or train operating companies, or some other witty connection.
Stu
Edit: It is also nowhere near grotty enough yet.
Coming along really well Stu. You have just gone past the point where I would use it if I really had to.
Best look away then Bob, it's going to get an awful lot worse !
Pipework going in this evening - just glad it dosen't have to pass water…
[user=465]Stubby47[/user] wrote:
… Pipework going in this evening - just glad it dosen't have to pass water…
Quite glad I don't need to!
For those of you with a delicate disposition, please avert your eyes…
YUK indeed :twisted:
