Diesel depot - Scalescenes R023
#103999 (In Topic #5505)
Scalescenes describe the R023 Diesel Depot model as a "modern structure". Is it a suitable basis for an end of steam/early diesel era layout, or is it too 'modern'? I've looked at the images on the Scalescenes website and still can't decide.
Perry
Looking at the model Perry
The wasp doors to me seem to modern but they could be changed.
The only other thing if you are trying to date something is the cladding he is using for the shed when that type was introduced i have no idea to me cladding at that time would have been the old steel or asbestos semi circle curved cladding that was extensively used for many years and still is today in plastic and fibre type board.
I see what you mean - use brick & you should be OK for steam/early diesel era.
Les
I'm about to do the same myself Perry and had decided that it was too modern. In the early days diesels often shared sheds with steam locos so to have something brand new was exercising my mind a bit too much for Sunday. I'll sit this one out if you dont mind and see what you come up with.:thumbs
Les
Devon Junction
Kernow Junction
Thanks for all the input, gents.
It's looking like a scratchbuild might be required then. I'll do some research and put it on the 'To Do' list!
Perry
I am building one for the D&S
Photo courtesy Scalescenses
The side walls appears to be fluted iron & the making of the wall is interesting to say the least
The top wall is as it comes after gluing the printout to card & the bottom wall is after cutting out the flutes.
As I add the inner & outer wall papers, I will take some more photos.
That looks fiddly Ron. Be interested to see how it goes as I have not managed to complete a scalescenes kit yet!!
Bob
Bob
Bob, do you mean that you have tried and been unsuccessful, or haven't yet had a go at a Scalescenes kit?  If the latter, why not try one of the free kits to begin?  They are fairly simple and straightforward.
Bob
I haven't had a proper go to be honest. I have been put off by all the cutting out and the gluing of the paper onto card. For that reason I have tended to use embossed plastic or plastic kits. Last time I had a go at a downloaded kit, I used the printed sheets as a template for embossed plastic card.  Maybe I should give it a go though.
Bob
Hi Bob,i started offf with Metcalfe and then tried Scalescenes as the next step.They are pretty straightforward and you shouldn't hold back from giving them a go.Also excellent value if you need a lot of structures to fill a space.
The fluting now glued to the inside wall
the external wall cover now glued to the flutes & while the glue is still damp, you can see the start of the fluting
now using 1/8th plastic tubing, I have attempted to create the flutes - not overly impressed
as can be seen, I have managed to dent the paper - so this side will not be visible.( or I add some rubbish leaning onto the wall )
OK, what I have done is to fix the fluted sides problem by using Evergreen Metal siding #4530 that has 3.2mm spacing
The roof capping - not that impressed for attempting to have a curved  cap from a piece of card that gets bent in 5 slight angles to each other - yes I know some bubbles in the paper above the doorways, this end won't be seen.
so following advice from others, I have changed it to this gable style
now to do flooring with inspection pits.
Last edit: by Sol
The location of the shed - back two tracks of the 3 straight ones.
the shed in the planned location
the track this side of the shed with a yellow sleeper( uncoupling magnets) is for diesel supply tankers, etc.
That looks pretty good Ron.
May I respectfully suggest you consider Post 23 here - http://yourmodelrailway.net/view_topic.php?id=1401&forum_id=11&page=2
Pick your card carefully and save the whisky tokens….
Ah, now I remember that trick, thanks Doug.
The floor in place
shed in position ( yes slightly fuzzy photo but once it installed permanently then a new photo will arise)
finishing off will be sometime as I have to ballast the tracks behind & do scenery before this gets "permanently" installed
It certainly looks grubby enough!
Added some more concrete & downpipes
this will do as regarding more details until I have finished the scenery behind it.
Hi Sol,
It's looking really good, can I ask what the yellow sleeper is and is that loco hoist the Ratio version ?
