Cattle Dock Build
(In Topic #5210)
I purchased some foam board off Ian and i thought do something small to start and get the feel of it, so i had this idea. I am building my farm and needed a cattle dock. This i got of a strange man who said he was a member on here, met him at the show, bit suspect if you ask me :doublethumb, reason being he went a bright red when asked about Discount, .
Anyhow i then realised i needed a ramp for the cattle to get up and so set about building one. Now its a tad wide but i intend to fence it off down the middle and use the space to stack straw bales etc, which they have to put on the wagons for the live stock. I cut the top and sides out of plasticard and then used a brick plastic card i purchased at the model show. It needs a bit more work, ie fencing, weathering and the sides doing but i would like any good or bad comments on my progress thus far if that is ok. Here are a few pics,
Ok please be nice i am a shy and young person just learning the hobby :roll:. You will nottice that a bit of balsa is not covered at the end of ramp. reason is i have carved a slight slope here and i will paint it some colour later.
Also what type of cattle wagon should i be using for this scene please. Thank you.
Last edit: by phill
Preferably a brown one for obvious reasons.
Look forward to finished work, Phill.
Last edit: by ddolfelin
You made the right decision to start with something small. That way you will see results quickly and learn lots about handling the materials.
You should run whatever cattle wagon you want. It's your layout and the period and location in which it is set are yours to decide. Just use the one you like the look of most.
Well done!
Perry
You might want to extend it all the way around the back of the dock and up to the rails, so that the bales of straw etc that you mention will be loaded and uploaded will not have to be lugged through the cattle pens….just a thought but it would also make an interesting area
If you have not actually fixed the balsa ramp yet you will find that with a bit of course sandpaper you could blend in the ramp to floor level easily by holding the ramp in your hand and dragging it across the sandpaper as long as you watch what you are doing it should blend in quite well
Oh of course you have gone GWRRRRRRRRRRR So you had better talk to Jeff
Tut still alot of jealous folk on here i see, just cause GWR knew how to build wagons, :thumbs
Hve you got any GWR Cattle wagons Phil ?[user=285]Alan[/user] wrote:Oh of course you have gone GWRRRRRRRRRRR So you had better talk to Jeff
Nigel:doublethumb
I have no idea if it's "prototype" or not but, if that were my cattle dowc, I'd go one stage further and put a roof over your paved platform. Any straw stored there would need to be covered against the elements and a simple "pole barn" type of covering with a pitched roof would be easy to do.
As Brian said, just sand the ramp bottom down so it's a snug fit at ground level. Cattle wagons ? Yep - just run what you fancy. If your layout is modern image (and I seem to remember it is) then the "Matilda" type of wagon would be fine. Steam era tended to have the smaller non-bogie cattle wagons as produced in many liveries by Bachmann.
Also there has to be room for the cattle truck doors to swing fully open and lie against the sides of the truck and room for the fall flap to go down onto the dock.
This photo should help a little bit, it's murky, but it's the only reference I have readily to hand showing the loading of cattle with the gates open - LNWR cattle dock fencing. The white thing on the far gate post is the base of a lamp, the actual lamp glazed pot is missing.
Nigel :hmm
Now as you can see in the pic below have built a small platform so far alongside the cattle pen. Someone suggested i go all the way round with it, well thats what i am doing at the mo, bit of nightmare but i have come up with a plan and well when i post a pic i expect i will get some comments when i have posted a pic.
Once its built the floor will need doing around it. I have decided to have a open platform going round the track to the other side, reason is so i can store some old farm gear in there, bit like you see in these place's. I spotted this when i was doing some research.
Watch this space for another installment. :thumbs
Still looking round for a csttle wagon.
Last edit: by phill
Sorry to hear about your possible job-loss situation - that's one 'ell of a change in just one week, mate, what's brought that about? Hang-in there,
Kind Regards,
Michael Thornberry.
Best of luck.
Anyway, the dock is looking just fine.
Just one suggestion and that is to fill the gap under the ramp. It needs to be solid to take the weight of them Bulls!
Cheers for now.
