Relocation
#235759 (In Topic #12999)
Ted
New Layout
Hi All
After selling all my machinery , and equipment . I finally have an empty shed .
The first job is to build an internal stud frame work . I have used a steel stud system .
Then to install the droppers , and frame work for the suspended ceiling .
By using a steel frame work on the inside of the shed , I have created a thicker wall
 cavity , and given a greater depth to the ceiling cavity . Which  has enabled me to
 use a thicker insulation in both the ceiling , and the walls .
 The shed measures 6 meters x 5.4 meters . which is large enough for the layout
I have been playing with for some time .
The next job is to install the insulation , and then the plaster board .
 Regards Ted
Ted, this work alone will keep you out of the pub for some time - - got a layout plan yet?
That's some shed !!!!  I'm totally green ………………………….. :mrgreen: :mrgreen: :mrgreen:
N.V. N.V. N.V. N.V. N.V. N.V. N.V.....need I go on any further?
Blurry eck think we could all fit in there ! Repeat after chubber   NV. NV .NV. NV NV.
Ted
Hi All
In answer to Sol's question . You can see from the quality of the photos , that the PUB
 is not that far away  .
 ,:cheers
 Petermac
  I always assumed that , the depth of  green in France , Was directly related to the
  amount of onions , that a Relocated Englishman was  capable of taking to morning market .
  The wiring has now been installed , and the insulation fitted .
  The door frames have also been replaced , and the first of the
  plaster board sheets glued and screwed in place .
 Regards Ted
Ted
Ted
Hi All
 As you can see , progress IS being made .
 The insulation has been installed . the Gyproc panels
 have been fitted . The electrics have been tested , and certified .
 Now for flushing the gyproc , and all the fiddly jobs .
 Regards Ted
Excellent ,crack on Ted.
Ted
Hi All
 I have now completed the old office ,to
 a work room .
Ted
Hi All
 Now back to the the main train room ,(SHED ).
The walls, and ceiling  have been flushed .
Walls painted , skirting fitted .
 Air conditioner , and carpet  left to do .
Ted
Ted
Hi All
 The wood for the main layout frame work has arrived .
I'm following along, Ted.   :cool:
I'm jealous Ted,it makes my 9' x 7' bedroom seem like a broom cupboard compared to your space.You could get a fullsize loco in there. :mrgreen:
Lovely space nicely finished Ted. Following along too.
Just a little impressed.
Following with great interest.
Keep up the good work and don't be a stranger in the pub!
That said, now the electrics are certified, do away with the aircon and install the beer fridge!
Gary
Ted
Hi All
 Thanks for the feed back .
 In reply to Gary's comment,
 Without the fridge the beer would melt
 Regards Ted
Wow, a massive space.
What is your grand plan (if you have one yet!?)
Ted
Hi All
 The air conditioner arrived today .
 Now I have to wait for the installer
to get busy .
 I also picked up a roll of cork for the track underlay .
 VERY cheap .
 Regards Ted
