Scratchbulding
(In Topic #12886)
How to cut windows
Hi All. I have read with interest the many scratch building tips, especially the Warehouse , an excellent idea for low a relief backscene. But I am having trouble cutting out the round part of window openings, the easy way is to have square windows. But, they don’t suit warehouses. Would some kind Modeller please advise me. Best wishes
For the serious plastic modeller, a pair of 'millwrights dividers' are the D.B.s for getting that important deep scratch line that enables a snap-out piece.
For large radii, i.e. arches, look up 'washer' or 'gasket cutter'. As a result of being an 'ole git who can't walk past a junk shop/tool store I have all three.
Don't forget to look at 'hollow' punches, work well in card for small window tops, Aaron sell a set for £6-£7 that go from 6mm to 2mm. Remember to use them over a piece of end grain hardwood for best results.
Paper template (use a regular compass or for arches a french curve, plastic or flexible) or as said steel or fiber washers to make the line (I use a 2H pencil to keep the line width uniform), nibbling pliers or old Xurons to get the approximate curve, curved or oval fine file to the line. I find with plastic it's easier to cut to about 0.5mm from the line and file to the line to finish. For straight sections make sure you have a flat file with one edge not milled.
I draw mine on the computer and print. Arched windows for warehouses are available from several suppliers. Grandt over here does them in a variety of scales with the moveable center panes. Saves the bother of doing all the panes.
David
index02
index02
Thank you again Matt . I do believe that I have more scrap stuff than new stuff as it happens . Best wihes. KevinKevin just practice first on some scrap plastic until you get the hang of it :)
;-) Cheers
This scratch built N gauge terrace uses Peedie Models etched brass windows and doors fitted as detailed above (not so happy with my attempt at slate roofing though)
Best wishes. Kevin
