N Gauge Tempsford
#206765 (In Topic #11343)
Eastern Region themed mainline
Those who read my 00 gauge Upton to Dunton layout thread will know of its demise and of my plans for something new. I have a heap of N gauge track used in previous projects and a good sized base board so I thought I would have a go at developing a a DC, BR 60s Eastern Region themed, N gauge layout with a mainline flavour. The layout not will be based on anywhere in particular, but will be influenced by some mainline locations such as Ipswich, Peteborough and (although LMS) Bletchley. Essentially a two track mainline with several platforms; it will also be a junction serving a rural branch that feeds several factories. That area will act as a storage yard for some decent length freight trains.
I have called the layout Tempsford, which is a village not far from me sitting on the East Coast Mainline. It has no station; but the name sounds good!! It is where I can sit and watch the Flying Scotsman and other high speed trains.
The station will need to be able to cope with several (minimum) 8 coach mainline trains as well as local services and I want some long runs so that big express trains can stretch their legs. Here is the overall base board:
The track I am using is Kato N gauge Unitrack. I have inverted one board to give me a river crossing and, at the moment, I have roughly set up the station area as below:
As constructed it could handle 4 x 8 coach trains plus two shorter ones (I may change this). The Kato points are good in that they are fitted with motors and pre-wired, they just need to be plugged into the switches, which in turn clip into the controller for power, so no wiring needed. The points have about a 30 inch radius and provide lovely smooth transition.
The downside of Kato track is that it has fixed curves, and although quite generous for N gauge (12 -13 inch radius) they still look very tight:
I would not be happy with this angular look. Fortunately Kato do a conversion piece of track which allows you to connect to Peco, so I bought a couple to experiment with:
It works quite well, so with some Peco flexi track I can create a nice sweeping 36 inch radius curve:
This has potential. I need to buy a couple of scissors crossings for the station area. Until I have those I will continue planning and adjusting before laying the track. Here is the river crossing area - scope for a nice long bridge or viaduct over an east coast estuary as inspired by the Colchester area:
Great fun!
Bob
I have been continuing to fiddle around with the track plan and have gone for a station running diagonally across the baseboard  that gives greater length and reduces the angular appearance of the layout. The station consists of two main line platforms - made from balsa and faced with brick paper. The platform surfaces are adapted Metcalfe items. There is a third platform for local services and sits on the goods relief line and the opposite main line also has a passing loop.
The next step here will be a goods yard that will run down past the signal box. Here is a J27 by Union Mills on the relief line:
I Have also done a bit more on the bridge, adding girder trusses:
With a J25, again from Union Mills, at the head of a coal train:
Yesterday I finished laying the track in the station area, which includes additional relief loops and the goods yard. The points are in (total 10), wired up and tested.
I also started work on a station building using the Kestrel kit, still to be painted and finished off:
And finally, a bit of testing, I dug V2 Green Arrow out of its box and gave it a run around. Looks nice, runs well but quite noisy - like many of the older Farish locos.
Nice big baseboards with plenty of room for some great scenics etc. won't be cramped on there.
Good progress as well.:thumbs
N guage gives a lot more scope ,just wish I could handle it,looking really good
:thumbs;-):cool:
web-cam 2.2.74.174:8081
if the lights are off no cam
Great start, nice to see some more N-Gauge!
'HOWZAT'
I know your still developing the layout Bob but I reckon the signal box would be between the goods yard throat and the running lines and turned around 180 to give the signalman a better field of view. Just a thought.
The scope for scenery is making me itch to get at it!
Keep it coming.
Keep it coming.
Thanks Marty, I think you are right. In fact it is where I had it earlier. I will rethink the location when the ballast and scenery goes in.
Bob
Over the weekend I have been working on the station buildings and a goods shed. I have always liked the Kestrel Town Station kit, but have not got around to making one. The model is old and a bit basic, but with a bit of work I thought it could look good. The biggest problem was the fit of the parts and some warping. I used filler and aluminium foil on the roof to fill the gaps. Here is the station after painting and weathering and some posters added:
The second building, which will sit in the sidings is a goods shed. Again from Kestrel, which makes up into a large shed:
In the meantime I have been weathering the track - more on that later.
Bob
Those buildings look great Bob - but then you always were a dab hand with a paintbrush. :thumbs
I also envy your ability to work in "N" Scale - it offers so much more space for "proper" trains but alas, neither my hands, nor my eyes could cope with it.
Looking forward to watching this develop. :cheers
Started to weather the tracks, which is essential with Kato track to get rid of the plastic look. I decided to try out the Woodland Scenics weathering "track painter" sticks. They are easy to use and so far I am quite pleased with the results:
Before:
After:
These are the paint sticks:
I have many yards to do yet, after which I will add ballast.
Bob
Last edit: by Bob K
Great thread Bob, envious of your layout room but then again we all get to share it through your posts. I too like N gauge but as with others my eyesight can't handle it, more please.
Ian
Nice job on the Kestrel Station Bob.
Thanks Marty. Apart from Metcalfe offerings it is really the only kit available of a decent size station. The rest tend to be village types. I suppose you could expand the Peco station by adding more sections.
Bob
As part of a job lot of box wagons I ended up with a bright yellow banana van that stands out brightly amongst its bauxite and grey companions. I decided to weather it and tone it down. This is the wagon:
The first thing I did was to give it a wash with matt black acrylic and, after removing the wheels, I painted them brown. They too were given a wash of black when dry:
Next I used a Tamiya weathering kit to tone down the van:
Here is the result:
Bob
Last edit: by Bob K
I have been quiet for a bit as there is not much to say about weathering and ballasting 30 feet of track; however at last I am able to say that this particular task is almost complete. Here is a view of the relief loops to the North of the station duly weathered and ballasted. I still have to do a little work around the points. I think the result improves the plastic Kato track quite well:
Bob
Disguises it really well Bob.
If it wasn't for the bits around the points, you wouldn't know from the pictures it was Kato track :thumbs
Wow!  What a transformation, Bob.  :thumbs
Nice work Bob, I think you need a new user name mate.   Pete.
