Testing a new loco on D C before using it on D C C
(In Topic #11239)
Running In??
Hi All I have just realised "Doh" that a new loco has to be "Tested" on D C, before putting in a D C C decoder, having purchased my "sparkling new" N C E Power Cab, I am rather miffed :sad: and:???: I only wish I still had my pair of H & M Duettes.:oops:Would some kind soul, out there, please advise me?? and if you know;-) where I can lay my hands on a "reasonably priced one" all the best Kevin
I think the advice may relate to the situation where you had a loco that is not DCC-ready, which hence requires re-wiring to fit a decoder. So it would then seem a good idea to make sure it's run-in and mechanically sound before making changes that are not easy to reverse.
Last edit: by RFS
Robert
If it comes DCC fitted, there's no need to go backwards.
None of my loco' have been rub in on DC. Some were tested on DC prior to conversion. I would go ahead and chip it. It'll be fine.
Just my opinion of course.
:thumbs;-):cool:
I used to be indecisive but now I'm not sure.
My strategy is to run the loco on DC (I built myself a really good controller with smooth regulated DC), then strip the whole thing down and start from the wheels, soldering on the pick up wires and the motor wires in the NMRA colours. Then pull out the grain of wheat globes and replace them with LEDs.
Add any ditch lights or beacons I desire, with the correct colours. Red for right rail. Black for left rail. Orange and Grey for the motor. Blue for the common (+). White for headlight. Yellow for rear light. Green and Purple for ditch lights. Pink for the beacon. Brown for the speakers. Etc, etc.
Or you could just plug it in and hope for the best. ;-)
Lenz has had the ability to run DC locos for decades, but like all other DCC systems, it doesn't supply DC power as we know it.
It's pulse width modulated (PWM), and while it will run ONE DC loco at a time, it's useless for pre-testing because it makes the loco motors buzz. In some cases it has been known to burn out the old (pre-can), motors.
The best idea is to get hold of a second hand DC unit, or build your own.
Oh, and running in on rollers is OK if you don't have a circle of track, but it doesn't put any load on the loco.
L E D's seems to be a manageable idea though, thank you again for your advice. all the best Kevin
(N C E Power Cab) that is, and I could not see a mention of D C at all.
I have been promised a D C controller and all being well that will fit the bill. all the best. Kevin
