Kingsway Models card kits
(In Topic #10155)
It's priced at £11 and, to save a little on international postage, I also bought this one, priced at £14 :
I'd heard that Kingsway, who specialise in London underground and bus station kits, aren't great kits but I did like the Georgian terrace. My idea is to add a few improvements - in particular, 3D printed windows from our own Wizmacnz.
At the same time, I'll offer my thoughts on how the kits compare with the likes of Metcalfe, Superquick and Scalescenes. At the price, they should compare very favourably.
Firstly, the Georgian terrace. Here's what you get for your £11 :
Plus an A4 sheet of instructions - not a great deal !!!
The first observation is that the 2 prints on the left and the pavement print are printed (mounted) on a high quality Bristol board about 1mm thick. Top right marked "thin" is mounted on thin card/thick paper similar to a greetings card.
Other than the board quality, my first impression is that they have some way to go to match the bigger manufacturers although they do obviously cater for an LT "niche" market rather than the mass market.
More to follow when I've had a better look.
There are two modeling philosophies - build a kit or build a model using a kit as a starting point.
Last edit: by Brossard
"Proper" downpipes are also called for.
I can't start it just yet but, once Peter has an idea of his 3D print costs, I can get some of the materials gathered together. This will NOT be anywhere approaching a "Dooferdog" quality build, more of an "it looks OK" type of offering.
I wonder if it could be scanned to make an extra pair. If so, that may be why it seems so expensive…………….:roll:
When you get a chance, measure the size of the holes for the window openings and I'll make a start on some Georgian windows to suit.
Windows are marked "Cut Out". The two other "openings" are for the doors.
Top row: h: 18mm x w: 11mm
Middle Row: h: 20.5mm x w: 11mm
Ground floor: h: 27.5mm x w: 18.5mm
Basement: h: 17mm x w: 11mm
This shot of the "backing layer" shows the window style in the kit (but they're only printed windows) Each panel is glued behind their respective windows/doors :
Looking forward to your ideas (and prices……). :thumbs
I had to go off and read the instructions before I could answer this one Reg. ;-)Where do the glass tiles fit Peter?
The kit can be built with a proper "below ground" basement - if you're prepared to cut a hole in the baseboard to represent it - or, it can be built as a "ground level" only house in which case, the walls are shortened slighrtly (cut off where the red arrows are) and the glass tiles are glued in front of the basement windows as "skylights" suggesting there's something below them.
If you've ever seen this type of housing, you might recall that they often had a small "pit" in front of the basement windows and the "ground" floor was up some steps probably 3 or 4 feet higher than the actual ground level. The rear gardens were usually at basement floor level whereas the road level at the front was considerably higher.
Looking forward to your progress with the kit , should make a good model with scope to play with steps to the front door. :thumbs
I typically glaze windows with a thin sheet of report cover acetate glued to the inside face of the windows. Sash windows I use two pieces one for the upper and one for the lower. I'll see if I can point the camera at a glazed window over the week-end.
That's what happens when you jump into the forum in a spare moment at work. I completely missed the context of Reg's question and that of course it wasn't directed at me. I think I've become more egocentric with age….anyway ….that is how I glaze windows.
Don't worry about it Peter - I was awake ……….cheers
If this is part of the window surround head it doesn't look quite right. I could make up a window with a surround a bit like the picture at The mayor's £1.8m house of Windsor... (converted from Max Mosley's office) | Daily Mail Online (middle floor windows of the first picture)
I need to know the dimensions of the rectangle above the window and the dimension from top of the cut-out to the bottom of the rectangle so that I can hide it with the surround.
Max is right Peter - it's a decorative slab - there to stop rain dripping down the windows. They thought of everything in those days - and made a feature of it.
The bottom of the rectangle to the top of the cut-out is 6mm.
The rectangle itself is 2mm deep by 17mm wide.
From your linked photo, I'd guess it protrudes around 6 inches from the wall surface in 12 inches to the foot scale. Also from your photo, it looks to be rather more than a flat slab having "layers" built into it below the top flat surface. I'd guess the top flat surface would have been covered in lead flashing to keep the rain out of it. As I said, they made features of everything.
I've batched them to see how the costs work out. Shapeways price says 14.50 Euro's including GST. That's for the twenty windows ground floor and above. There are another 4 basement windows, so probably 17 to 18 Euro's (whatever they are).
Just a couple of questions - what's the thickness of the "web" between the window frame and that decorative overhanging rectangle - or are they designed for the web to be removed and just use the window and rectangle ?
There doesn't appear to be a sill on that same "middle" window. Is that intentional ?
The pack shot shows the left hand windows in pairs. Again, is that for ease of print/packing and they are separated on arrival ?
I don't think the price is at all bad - for the quality, it seems much cheaper than the kit itself ………..:cheers
p.s. Euros are quite nice things with pretty pictures on them. ;-)
