Buildings as Low Relief
By Raymond Stewart (GA, USA)
I have colored a building I found on the Internet using MS Paint and gave to a friend as a backdrop building. It works fine. However you will need to place it on thick plastic or foam core board to keep it flat.
Hints & Tips No.333
Underground "Utilities"
By Tom Decker (Michigan)
Since I am building my layout on flush doors, I run wires for structure lighting and track power through the styrofoam scenery base. Just grind or file teeth on the end of a piece of 3/8"(10mm) tubing and chuck it in your electric drill. Bore through the styrofoam as needed, remove the tube to clear debris, then reinsert it and the wires will push through it easily. Pull it back out, leaving the wires in the hole.
Early Steam Engine Repairs.
By Trevor Gibbs
Early die-cast and plastic steam locomotives are usually fairly “bomb proof” but can develop a bit of a gait in their movement. Make sure that both the worm and the gear are clean of burrs which may stop the motor from doing its stuff. The other concern is binding valve gear.
Gently remove your valve gear and using a “larger-diameter-than-the-hole” twist drill, twist it with your fingers to de-burr your valve gear slot where the side rods are screwed to the wheels… and do not over do it!
Hints & Tips No.335
Locomotive Tuning
By Ted Allan
I recondition my locomotive motor armatures by carefully dismantling my motors, putting my armatures in a lathe. Before I had the Lathe, I used to use a power drill held in a vice. While it is spinning use some Aluminium Oxide paper to true and smooth the commutator.
I then clean out the slots using a pin, making sure than I can see the mica insulation and that there is no copper residue. I then reassemble and lubricate the motor sparingly. The result in smoother running is worth the effort.
Making Diamond Tread in Brass or Styrene
By Graham Ross
By using an old file and a heavy vice, you can tighten the vice with the file and soft brass or styrene to make diamond tread pattern for scratch building. This is very hard on files so use old ones for this.
Hints & Tips No.337
Nail Polish as Insulation
By Harold Shelton.
You can use Nail polish as an insulator between wires. If you create bare wires close to each other, simply paint it on. It dries hard and will burn with high currents and voltages but is very durable for model wiring purposes.
By Harold Shelton.
Hints & Tips No.338
Extending File Life
By Graham Ross
You can improve the life of your files by regular cleaning. Either use a cheap bronze wire brush as a file card or use some sharp edges to pick out the swarf in the file. It is also a good idea to run some chalk over your file which will help stop fragments building in your files teeth.
Building from a Scale Drawing
By Trevor Gibbs
If you want to use a paper plan for a scratchbuilding project, overlay it with a piece of waxed lunch wrap. That way, the drawing is protected from glue and you can constantly check your work.
Hints & Tips No.340
A Newer Way of Mounting Containers?
By Ian Cant
If you are modelling containers either old or new versions, try using steel weights under the floor of your flat cars. Inside your containers, use a fairly strong magnet such as a rare earth magnet from an electronics store.
Your containers can then be removed and no unsightly single edged tape, glue or anything else, and your wagons or freight cars will have more weight for better tracking.
Making Neon Signs
By Graham Ross
Fairly effective Neon Signs can be made by shaping wire to you required shape then painting your wire with luminous paint. The light about your building should give enough of a glow to light these in the dark.
Hints & Tips No.342
Using a Digital Watch.
By Robert Ferus (New Jersey, USA)
In N scale given the size a clock tower would take and how small watches are not at the moment, consider using a digital watch for a bank sign.
I have been dragging my feet a bit with posting Hints and Tips due to a couple of personal issues (wife receiving treatment but caught early and other duties as well) but also in part because the hints to the end of 499 went AWOL. Happily, I found them, today in fact after the file I thought was accidentally destroyed on a Portable hard drive that died was also on one of my cloud drives! So at the current rate we should have input for about 18 months. Hope that does not worry you all too much and I have had a pretty good innings seeing I started helping Brian MacDermott (who started the Model Rail Express hints and tips column15 years ago!!!
I will still post two a week rather than every three days as I was … that would keep me a bit more in sync than what I was before!
Hang Your Controller
By Loren Hall (Washington State, USA)
Tired of your dcc controller laying on your scenery? I attached a 3M Command hook to the back of my Powercab, screwed a eye hook into the fascia board, now I can hang the controller instead of laying it on the table.
Hints & Tips No.344
Planting “Cabbages” and other vegetation in OO.
By Graham Ross
You can represent Cabbages by “planting” whole cloves from your spice containers and painting them green in OO scale.
Corn fields can be made using green toothpicks slicing down the sides to form the leaves then painting some bright yellow on top. This takes a bit of work but would look very effective.
Hints & Tips No.345
Planting “Cabbages” and other vegetation in N scale
By Mick Lovell and Graeme Goodsell (NSW N scale Group)
We made rows of Cabbages and Lettuce for the N scale “Illabo” exhibition layout here in Australia with dyed sawdust rolled into a ball. A vine growing over a back fence was made by painting a trace of PVA glue and sprinkling with fine ground foam.
We made ferns in hanging baskets from asparagus fern glued into a painted bead of glue and hung by fine wire.
Hints & Tips No.346
Climbing your Telegraph Poles
By Trevor Gibbs (Melbourne, Australia)
Using the ordinary paper staples, you can make maintenance climbing stirrups by drilling a staple into the pole then cutting it off with side cutting pliers. Thin but fairly durable.
Bottles and Other Details
For the “Illabo” N scale layout we created model drink bottles by heating and drawing out fishing line to make a bottle neck. A washing line has some shapes cut from white paper, dampened, crumpled and spread on a fine wire line… and if these can be done in N scale..
Hints & Tips No.348
Answering Questions… at home or at an Exhibition
By Roger Joel
How many exhibition layouts have we seen where the sullen operators skulk behind the layouts appearing to openly defy anyone daring to ask a question.
Yes it can get a little tiring answering the question 'How did you make the rocks on the layout', for the umpteenth time in a day, however I reiterate the idea of encouraging the future members of the hobby. A friendly response also helps to create a positive attitude at the exhibition and so hopefully encourages visitors to return another year. When exhibiting we always try to have at least one group member available behind the layout to answer questions.
