Making Wagon Sheets (Tarpaulins)
#266514 (In Topic #14524)
Weather protection for your miniature wagon loads.
Yes, you have always called them tarpaulins but, in fact, they should really be called wagon sheets. I bet you didn't know that, did you?
Anyway, how to make them in model form?  Let me start by saying that basic idea is not mine. I read about it on another forum and ran with it, adapting it to suit my own particular requirements.  This method should be suitable for any of the smaller scales up to and including 7mm scale.
I model 4mm scale and the examples shown will be in this scale.
There have been discussions before on this website regarding the best material to use for the wagon sheet (or tarpaulin if you must), and even a discussion on the most suitable material for the miniature ropes, tea bag string even being suggested.  I wish that I had seen that before I started.
So to work.  Firstly, if you live in the UK pop along to your nearest supermarket and buy yourself a pack of Tunnock's caramel wafer biscuits.  They are those lovely chewy, chocolate covered wafer bars, which are particularly nice with a hot cup of tea.  I understand that Tunnock export worldwide so hopefully those of you not fortunate enough to live in the UK might be able to get your hands on them. Failing that, get yourself a UK penpal!
Next, pop the kettle on and make your favourite brew.  Enjoy one of the caramel wafers but do not throw away the foil wrapper as this will form the basis of our wagon sheet.  The foil is attached to a paper backing which forms the inside of the wrapper.  This paper will be the outside surface of our wagon sheet.
Now, down to business.  Brush off any chocolate clinging to the inside of the wrapper and screw it up into a ball. Now carefully unwrap the ball and gently smooth out the wrapper.  It should now be covered with small creases and be quite pliable. Remember that it is the paper side which will form the surface of our wagon sheet.
Wagon sheets were usually around 21 feet long by 14 feet wide, or thereabouts.  So, with reference to your particular modelling scale, cut the required number of sheets from the wrapper.  Each wrapper will provide two wagon sheets for 4mm scale and one for 7mm scale.
The following picture shows two wagon sheets cut from one wrapper.  The ink marks on the paper side are a result of my working out where the ropes would be attached.  Once I had established the positions I transferred the marks to the rear (foil) side of the sheets.  I would add here that my intention was to make two sheets but I prepared six, my reasoning being that I would probably make a hash of the lettering and numbering on some of them.  The idea was to select the best two at the end of the process.
It appears that wagon sheets in the steam era were normally black in colour.  My sheets were intended for my Southern Railway layout, Farleigh, so they would be black with white lettering/numbering.
I painted the paper sides of the wrappers with black acrylic paint from a cheap tube bought for £2, which I mixed with a small amount of white.
More soon.
Last edit: by col.stephens
Strictly speaking, the wagon sheets for the Southern Railway, and some other railway companies, should have the company initials, sheet number and manufacture date on all four sides.  All I was looking for was a reasonable impression of the lettering/numbering so I decided only to put them on the two long sides.
In my armoury of tools I came across this paint pen which had been purchased for a previous project…
Don't be fooled by the words 'extra fine point' as the resulting paint line is over 1mm wide, although this is suitable for our needs.  I did consider using a paintbrush but thought that the pen would be more controllable.
In order to ensure that the numbers and letters were correctly positioned on the sheet I made a small card jig. The appropriate positions of letters and numbers was ascertained from a book in which I found drawings of the sheets used by the Southern Railway (An Illustrated History of Southern Wagons, Volume Four' published by OPC).
As you can see, when the left-hand side is lined up with the left-hand edge of the wagon sheet, the rectangle marked 'S' is in the correct position, and when moved to the right, that marked 'R' is in the correct position.  The holes are cut to the correct height and width of each letter.
The small, long rectangle at the bottom gives the correct height for the numbers and is placed centrally beneath the letters once they have been painted on the sheet.  The bottom edge of the jig is lined up with the bottom of the wagon sheet.
To prevent the paint from creeping under the edges of the rectangular holes, I glued strips of card on the reverse side of the jig to lift it slightly away from the surface of the wagon sheet.
The company initials were applied with the paint pen using the jig as previously mentioned.  The resultant letters needed a certain amount of refining to get the correct shape.  To achieve this I used a Pilot drawing pen and a straight edge.  The pen contains black ink.
When satisfied with the letters the numbers were then applied, once again using the jig.  As with the letters, the numbers were tidied up with the Pilot pen.
Once happy with the numbering, the sheets were given a spray with matt varnish to eradicate any shine left by the Pilot pen black ink.  The sheet was now given a couple of washes of thinned brown acrylic paint to tone down the lettering/numbering and give it a weather worn look.
To represent the ropes I bought a reel of polyester thread of an appropriate brown colour.  Lengths of the thread were glued to the foil side of the sheet, with five along each long edge and three along each short edge.
My chosen wagon was built from Cambrian Model Rail's kit No. C33 - LBSC/SR 5 plank open wagon.  I chose to make the kit to include the bar to support the wagon sheet.
I draped the wagon sheet over the bar and placed three dots of superglue along the length of one wagon side.  I found that  my usual white acrylic glue would not hold the foil inner in position. The sheet was positioned and held in place until the glue got a hold of the foil inner.  This was repeated on the other side of the wagon.  The ends of the sheet were folded and secured with a few dots of superglue.  During this process I referred to photographs to get an idea as to how real wagon sheets were positioned.
Another compromise was now necessary.  Obviously the ropes cannot be secured to rope hooks on the solebars as per the prototype, so the ropes were taken under the solebars and secured underneath with a dab of superglue.
On the wagon ends a similar situation occurred although two ropes were diagonally crossed and secured around the buffer housings.  Again, not strictly prototypical but it suited my purpose. At this stage I touched up some of the edges of the wagon sheet as the foil inner appeared to be showing slightly in places.
And here is the wagon with the wagon sheet in place.  I think that it captures the general look of the prototype and is not often modelled.
I mentioned that I required two wagon sheets.  More on the other wagon soon.
That's nice Terry - any excuse I can get to try those Tunnock's caramel biscuits is most welcome …………… :lol:  I think they must have deleted our part of France from their export portfolio - I've never seen them here but assume "other wrappers" are available ………… :roll:
 Sheets or tarpaulins eh  -  :hmm   If you're a sailor, ex or exisiting, they'd have to be tarpaulins.  A "sheet" is a totally different beastie on a sailing boat…………….. ;-)
Incidentally, in days of yore, a company called "Smiths" produced a very good representation of wago tarpaulins (sheets) - not sure if they're still available.
Hi Terry,
I use the printer and a template drawn up in a graphics program (CorelDraw or similar). White or very light grey lettering, dark grey background). Use lightweight cheap paper. Print, then crumple/fold the paper until the fibers get broken. Cut and fold to shape using glue to keep the shape. New sheets have white lettering, almost black background. Older ones grayer lettering and mid grey background. I use the spray function for splatter.
"The spray function" ???   :hmm
You get the "spray function" from eating a Tunnock's biscuit while you are working on a wagon sheet.  :lol:
One of these days I'll get into putting wagon sheets on my N scale rolling stock, it will be an interesting exercise in miniature modelling… thanks for the suggested methods. very useful.
Last edit: by Marty
 :mutley :mutley :mutley
I think they still are but not sure where. Occasionally on fleabay.
se next post
Last edit: by robberdoc
I think they still  are but not sure where, ie primary source, occasionally on fleabay
Spray function? Most draw/paint and edit software has a spray gun function that can speckle using a different color. Basically a localized random pixe! color editor. Useful for cat tail weathering streaks on the ends of wagons as well.
If and when we are running properly I'll do some examples. Early pre grouping tarps came in various colors for lettering. Watch the tarp dates if a rivet counter, they only lasted a few years. A 1930s tarp on a wagon in the 1950s would be a bit odd.
Thanks for the explanation Nigel - I hadn't heard the term before - at least, not in this context !
Thank you all for your comments.  The Smiths' tarpaulins are still available for around £5 or £6 for a pack of five.  Here is one supplier, other are available:
Smiths Tarpaulins OO Gauge - Smiths Tarpaulins OO / N | Peters Spares Model Railways
Peco also manufacture wagon tarpaulins at £10.20 for a pack of eight.  They are printed on what appears to be felt and despite Peco's claim that the material convincingly replicates the textue and look of canvas, I remain to be convinced.  See one here:
SR Wagon Tarpaulin
OO Scale SR wagon tarpaulin, produced from a material that convincingly replicates the texture and look of canvas tarpaulins once commonly used on open wagons, to protect the contents underneath. Each product contains 8 tarpaulins.
View
As mentioned previously I required two wagon sheets.  One has already been shown adorning a wagon earlier in this thread.  The other is in place on its wagon but further detail is being added to make this a really interesting model.  All will be revealed shortly.
And now we come to the second wagon sheet.  Whilst perusing my books looking for photos of wagon sheets to establish how they were used on the railways,  I chanced on an interesting picture.  The open wagon pictured was covered with a wagon sheet which was sagging under the weight of a large pool of water.  Apparently, this was quite common although I have never seen it modelled.  This struck me as one of those situtions which was crying out to be done.  I selected a Bachmann generic wagon in SR livery as my victim.  Two large rectangles of card were glued together, one on top of the other, and they were glued to the inside of the wagon.  This block of card was intended to support the centre of the wagon sheet.  The sheet was glued in place starting with pushing the centre down onto the card block to which glue had been applied.   The ropes were glued in place beneath the wagon as shown on the wagon previously completed in this thread.  Over the course of about six days a number of coats of gloss varnish were brushed into the well which had been created in the wagon sheet.  I chose to use Humbrol gloss varnish as it is of a thick consistency which I thought would be useful to build up the layers and give some depth to the 'water'.
Anyway, here is the finished result with which I am quite pleased.
Hi Terry,
Your photos show the tarpaulin is waterproof!
Your work has inspired me to do tarps for the Mining Railway in Wombat Creek.
