Low relief high street shops
(In Topic #10206)
I know my skills are nowhere near the standard of "others", and I have rather rushed bits of the kit because I'm so short of spare time just now, but nevertheless, I've become a big fan of John Wiffen's offerings.
Yes, they do take a long time to build if done well and no, they're not as cheap as first seems by the time you've bought the card and printed it all out, but they make up into incredibly strong models.
Here's some photos of part of the row almost completed. The two larger shops - Boots and Maxmill Electrics - are glued together which has to be done before completing the "common" centre chimney stack :
There's a massive range of internal fixtures and fittings supplied with the kits plus, some printable name boards for personalising the shops. This row is planned for "Station Parade" alongside Maxmill Town station.
I build each shop with it's own "base and pavement". The join will be covered by a representation of the metal channel taking rain from the fall pipes to the gutter.
I also forgot to allow for internal lighting until it was too late but, as there's a whole parade of shops to build, later ones will have lights (and be slightly more carefully built !! :oops:)
I think you may be a bit harsh on yourself. These look really good to me. I'd be delighted with results like that.
I'll look forward to seeing a picture of them " on parade "
thumbs;-):cool:
Mike - they're great to build and, unless you've built a Scalescenes kit before, you simply won't believe the strength of them.
The fittings in the shop windows really make a difference.
Well done!!
:doublethumb:doublethumb
:cheers Gormo
(If I had the money I'd take out shares in UHU.)
Great fun to build. :cheers
Bob
I take your point about the model shop - but this one is only a "pretend" one……….
I think there's room for all sorts of card kits on a layout but, sticking to just one manufacturer is, IMHO, a mistake because they do become "generic".
Metcalf kits are certainly quick and easy to build so a row of something would look good. The problem is, they're "too popular" so your row looks exactly like everyone else's row. Maybe that day will come with Scalescenes but, because they take much longer to build, I think it may be some way off yet. Also, they're much, much stronger than Metcalf kits.
Thet's where John Wiffen has got it spot on - his printing is perfect. :thumbs
On my ones, I have started to use a 2.5 - 3mm double sided foam strip down the side of each window, then stick the curtains to that. It gives a lot of depth to the windows.
Paul
I use offcuts of the 1mm card for the same job. As you say, it just takes the curtains back a little. Maybe I should try something thicker - given that you hadn't noticed they were set back ………………….hmm:hmm Too thick and I suspect they'd be in danger of disappearing into the blackness of the interior …………:roll::roll:
Use cornflake packets or similar,they won't look any different,trust me.
I have save your pics for future inspiration.
Last edit: by AndyG
The Newcastle Model Railway Club
