Stu's Boxfile Layout
(This is just my size)
Even at this early stage,this is looking really promising! I sense a Classic in the making!
Ha-ha !! :Happy
I have managed to successfully proved my theory of how to articulate and power the wagon turntable.
I cut a rough 7cm circle of  Ian M's 3mm foamboard. In the middle, I cut a small square hole and push-fitted the top part of a small Lego rotating plate ( swiped from No 2 sons' Lego pile -  I had to root through three large crates to find it !). Setting the base of the rotating plate into a sqaure hole in another piece of foamboard allows the top, circular piece to rotate with minimum friction, but enough to prevent free turning.
A bicycle spoke was then attached to top plate, to provide manual power and control.
As this was a rough mock-up, I will be re-making this at home late, using proper tools and will then post some photos. The rails will be added direct to the top plate, spaced correctly and the rest of the plate will be covered in planking - either coffee stirrers or matches or similar.
But it's going to work :cheers .
Well, to prove the turntable does work, here is a video : http://www.youtube.com/watch?v=vDCmJrAr4As
It also shows the coupling hook being raised, before the wagon is turned. This is done by moving a magnet under the turntable, which would happen once the loco has pushed the wagon into place.
Stu
Last edit: by Stubby47
:thumbs:thumbs:thumbs:thumbs Cool!
:doublethumb  Excellent!
Isn't it great when a plan comes together!
Wayne
Last edit: by Wayne Williams
Thanks for the comments.
The next job will be to finish the ground works around the table, so I can add the track. I've found that I can use the Ratio / Wills window arches as a circle of edging stones. The table will have scribed styrene as a wood effect - not sure yet whether to add the other tracks at 90 deg - did tables always have crossed tracks on them ?
Of course, progress depend on what other domestic duties are conjured up for me…
Stu
Stu, photos I have seen, show 4 rails  with 2 at 90 degrees
Wagon turntable
Wagon turntable
I Googled  "wagon Turntable" then selected Images
Sol, thanks, that's a great photo for detail.
I probably will add the other tracks, but they will have to be non-working ones, as I've stuck the first pair down with no breaks in for the crossing.
Unless I use the dremel….
Stu
Stu, all those I have seen either 'live' or in photo's have had the cross tracks, saves moving the table (again) when the next wagon either needs turning or a 'train' is running along the 'main' line, cosmetic will be OK though in the box file…..
Thanks Sandy, I thought that would be the case. If the table had built built to rotate 360° deg I'd not have asked, but it has a limited turn of only 90°.
Excellent :thumbs
A bit more prpgress has seen the addition of some ground cover, in the form of a large piece of Slaters plasticard.
The white edge stones are simple card punches.
Looks just the job Stu. :thumbs
Splashed a bit of paint around yesterday, plus made a start on the front wall of the loading bay warehouse. I still need to complete the turntable, I've got one of the non-working rail pieces on, the rest need to be cut to size then pva'd down.
I'm not sure whether to use coffee stirrers as the wood base - they work out at a scale 1'3" wide, which I think is too wide. Another option is to use embossed plasticard, but this is to thin and will need packing up first.
You could always scribe a line down the middle making each one two planks.
D'oh! Why didn't I think of that…….
Thanks Ian.
Stu,   what's the origin of the brick (paper?) on '.. the front wall of the loading bay warehouse. ..'
Hi Sandy, it's Scalescene's TX06 Aged Red Brick. The quoins are from one of the various stone sheets.
Some more progress on the boxfile layout.
Box 2 is now coming along nicely. I've added the main building for the wagons off the turntable to be processed, with the rudiments of the roof and second floor added as well. This bit, of course, will be removeable.
I've also managed to source a suitable rod for the point control - the original wire in tube was fine for the older dead-frog point, but failed to move the new live frog variety, so something had to change.
Apologies for the odd background in these photos…
