Weathering
(In Topic #10994)
Rusty Rails Paint
Hi All I am still planning ahead, and I have been watching Youtube:sad: and I could not find anything that grabbed my attention!There must be someone out there in Y M R C who has some thought provoking tips on Rusty Rail Paint. I had thought about Aerosol Paint but even if I did the work in the garden it might blow everywhere? then I thought Humbrol paint and a brush, but even on my small plan it would be "Like Watching Paint Dry" worse than ballasting? Speaking of Ballasting which should come first?? Ballasting or Rusty Rails?? But unless Railtrack or WHY have just laid new track you would not expect "Clean" ballast on a railway line (unless of course it was a Preservation Society Line??");-) But seriously can anyone help me achieve Rusty Rails? all the best Kevin
I ballast first, then I paint the rail webs and feet with Raw Umber acrylic.
It dries to the perfect rust colour.
I use a small sable brush with a long handle for better control.
I wipe the rail heads as I go with my finger.
As I'm going along, some paint gets on the spikes, which looks good.
If any gets on the ties (sleepers), I wipe it off with my finger.
I'm doing 25 metres at the moment.
As I finish each section, I wash my finger. :lol:
It's easier to wipe it off the rails when it's wet. It dries so fast, I need to wipe it as I go.
When I'm finally finished, I polish the rail heads with 1200 grade waterproof paper.
Cheers, Pete.
I then paint the rail sides using neat Raw Umber using a rigger brush (Rigger brushes have long bristles), followed by picking out some sleepers in Raw Umber, Dark Grey and some in Black.
I clean the railtops as best as I can as I go, then clean up at the end like Max with 1200 Wet & Dry
I ballast afterwards and go over the whole lot again with the 1" brush with a thin wash of Raw Umber/Black with a final clean of the rail tops.
Andy
Andy
I ballast after painting, but then I use thin sleepers and a glue painting technique, not the dropper from the sky. That way the sides of the sleepers get painted. I also use modules with no back-scene, which means getting at both sides of the rail is easy.
There is some merit in spraying everything with a thin coat of dark grey etching undercoat (for the car) before starting. Rail sides (to the top on the outside, not quite to the top on the inside), chairs and sleepers in that order. 2-3 yards in an evening session for the paint, it's soon done. Use 1000-2000 emery (car paint finishing) on the top and inside edge of the rail head to get rid of any excess after the paint has hardened. Do not use Peco rail cleaner pads, they scratch the rail and reduce friction (and thus pulling power).
Check photo's or go and have a look at real track. There is quite a subtle variation in color, especially when looking at new versus old track. Modern steel alloys are designed to rust immediately, the surface oxidation is stable and they do not need painting. Example below from Banbury Station of BR 3 bolt BH track from the 1950's still in light use. If you are using Peco track it has spikes so you don't have to worry about chairs. Second example is of modern FB track on concrete sleepers in the station - it's dark grey with a hint of brown. Last photo is from the East Somerset Railway, a preserved line. Rusty red patina on the top from once a week running. Difficult to do, old brass track is a fair substitute with the sides painted. Devil's in the details.
It's difficult to get that hammered shine with nickel silver track, which is a brass alloy, as it oxidises quite rapidly. If you want that look it's steel rail, but you have to be a purist to go for that.
I tried Vallejo burnt number last night (Max's color), bit too dark for me. 50:50 with Vallejo rust seemed better. Rail rust color depends on the ambient light, so it's worthwhile testing where the layout will be until you get what looks right to you.
I airbrush my whole track railmatch sleeper grime (acrylic) as we can't get Railmatch enamels in Australia. I then ballast and then go over the middle of the track in different spots mainly in the engine shed and station area with Matt black (railmatch) to resemble fuel stains. Although it's wheather you want your ballast dirty or not is the decision you make when painting track. This is on n gauge track so I don't tend to brush paints the rails rust because of the 'fiddlyness' but if U were doing OO I probably would.
Here's a clip of how I airbrush the track.
Last edit: by CCGWR
