To weather or not
(In Topic #13534)
Purchasing a new Loco or Carriage
Hi All. I have been considering weathering, but I am yet to master the job. And then one day if I did master weathering, where do I stand with a new Loco or Carriage. If I was consider the re sale or exchange from another vehicle, it could be be devalued. Maybe I shall have the new stock as ex paint shop, and direct my attention to old or very cheap preowned stock. Best wishes Kevin
If you bought your railway loco`s as an asset then you dont touch them unless your an expert.
If you bought them for fun and your pleasure and not an asset then when you feel confident enough weather them.
That way the value does not matter as many of us will have them till we go to the pearly gates and all that will happen then the executor will have a dealer around who will give 30% of what its worth retail so it dont really matter if you weather or not.
The day you bought it it was already devalued. Start with an old body shell or cheap non-runner. Weathering pigments and a set of decent fine bristle brushes is easy, if you don't like it wash them off. Study photographs to see what goes where. Black, grey, red rust, orange rust and white works for most things. Start with grey, then move on getting lighter. Use black for oil patches. Shiny black - mix the black pigment with a bit of acrylic clear gloss diluted 50:50 with water or acrylic paint diluent. Use a fine brush to set in place. A basic kit is not expensive.
Airbrushing gets expensive, decent low pressure airbrush and a set of nozzles, paint resevoirs, compressor and air reservoir, a booth to prevent the mist from going everywhere…my set-up with a Paasche single action was over $200. And this is a basic model airbrush.
I started on a couple of small wagons by inking in the gaps between planks. It grew from there. I taught myself the rudiments of powder weathering and own, though seldom use, a Paasche airbrush.
I now find myself, some ten years or so later, being invited to give demonstrations and attend exhibitions. The most recent development is two requests to provide master-classes to experienced and award-winning modellers.
My encouragement to anyone is to try it. None of us knows what we are capable of without trying. Start small. Powders and water-based paints come off if you really don't like the job. Ink and enamels don't. But you can usually turn even the worst job into something better by walking away and coming back another day.
Fine detail straight lines might not be easy but if you can manage to find a grip on the brush - or better still get hold of a brush with moulded grip on the handle - then you can probably make a start.
The better quality your brush the better will be the end result. I invested in a red sable brush around 8 years ago which remains my number one weathering brush to this day. It wasn't expensive but you won't find one in Poundland!
There are days when I simply can't hold the brush but they are very few. Weathering can wait for a better day. Unless, like me, you are giving demonstrations! I have only had to cancel one event so far.
Why do you need to hold the powder? The brushing action embeds the powder in the paint. It helps if you give the body shell a spray with clear matt acrylic. It is softer than the original paint, and weathered stock was not shiny!. Unless you handle the body with greasy fingers it stays there. Wash with a soft toothbrush removes it. Spraying the powder afterwards with fixative is problematic. Use India ink for dirty door frames/panel junctions first. Comes in many colors, apply and wipe off excess.
There are specialist brushes for fine lines or streaks (rust, water scale).
This was done with powders and rust acrylic.
. Use sable or synthetic equivalent.Less ootoob, more DIY.
I use a lazy susan which my wife declared surplus to kitchen requirements and was promptly repurposed in the workroom. It has the twin benefits of multiple dishes to hold and blend powders thus giving a selection of shades all ready to use and it rotates to allow the one I want to be nearest to hand every time.
Perhaps I should add that I don't seal powder work afterwards either because no matter what you spray it with you will wet the powder which then turns momentarily to liquid and can run, dissolve or at the least turn into blobs.
I do use hair spray as posted above but it must go on first. It must also not come into contact with the glazing as some sprays will cause some glazing material to craze. As I discovered when attending to a CK corridor composite.
Luckily the coach in question is maroon and therefore I can claim that when it appears (which isn't very often) it is steam heated and the windows have fogged up! There's a positive side to almost anything ………
We go to the "N'th" degree to make the trees look good, to make the grass stand up, to make accurate copies of buildings, even for some, researching signalling convention so our "masterpiece" looks as close to the real thing as possible.
Then we plonk a toy train on it !!
Accurate models they may be but, as Rick said, when did you last see pristine stock on a railway ? Railways, particularly steam ones, are very dirty beasts. Why should we want shiney stock running on ours ? It just looks odd, out of place and in stark contrast to what we're trying hard to create.
Of course, I'm not including collectors in this - their "collection" must be absolutely pristine in every facet - box included. Unfortunately nowadays, thanks to mass production, their collections are never going to be worth the price of a Rembrandt.
I say weather - but yes, practice on something you can afford to throw in the dustbin first …………………
Yes, the effects of nature on the natural and man made environment, coats every sinlge thing out of doors and those layouts looking most natural to the eye, have undergone a comprehensive approach to weathering, utilising a simple integrated pallet of colours and products.
The very rare occasion of an almost pristine loco may be seen in the real world, but observing a whole townscape with brand new roof coverings simply defies reality.
Weathering is best considered as an integral part of modelmaking and that is where the consistant use of a restricted colour pallet aids the recreation of reality.
Weathering is also a pleasing activity and with the adoption of a consistent approach, the whole layout will automatically become more believable.
Each to the own though and many will still be happy with playing trains. Rule One still applies!
There is an interesting thread on Railpage Australia
https://www.railpage.com.au/f-p798748.htm#798748 which you could possibly use as a bit of a tutorial. Although I have not tried weathering at all, I have a couple of weathered items done by others and they stand out well. One of those projects I will get to…
Having said that, having seen many trains from a roadside, although not pristine glistening brand new, the effect of distance is such that weathering effects are often not quite so noticeable from a viewing distance but colour variations due to weathering are. So Blood and Custard coaches or SR green ones will be obviously different in the tones that present themselves to the naked eye as all the coaches in the train would have been repainted at different times therefore faded to different levels.
I would suspect that even just a coat of Dull Coat would assist in making your rollingstock a little less "out of the box".
Hope this helps
You must be younger than me ……………………………….or more likely, the Southern Region was colour blind ……
