Trees from Spirea Shrub
(In Topic #4986)
Ken.
They do look very winter tree-ish already though.
soon gets very brittle.
:lol::cool:
http://en.wikipedia.org/wiki/Glycerol
Glycerol is a component of glycerol soap, which is made from denatured alcohol, glycerol, sodium castorate (from castor), sodium cocoate, sodium tallowate, sucrose, and water. Sometimes one adds sodium laureth sulfate, or essential oils for fragrance. This kind of soap is used by people with sensitive, easily-irritated skin because it prevents skin dryness with its moisturizing properties. It draws moisture up through skin layers and slows or prevents excessive drying and evaporation. It is possible to make glycerol soap at home.
[*]Glycerine is used as an anti-drying agent in watercolor paints. [/*]
[*]Glycerine is used as a preservative to keep tobacco mixture moist. [/*]
As for the dead Spyrea, that can also be stood in the same stuff and the twigs will suck some up by capilary action. When dry, it's then best to spray the heads with a matt varnish to ensure that the end bits remain intact.
Enlightened Doofer
Another alternative is to go to the other end of a plant and use the roots. Some plants have very fibrous, branching roots that look just like miniature trees. The main root can look quite twisted too - bit like Hawthorn trunk. The beauty of having so many branching roots is that some can be removed and a large piece of root shaped until it looks like a tree - ready to have pieces of sea moss attached.
The obvious problem is that you wouldn't want to dig up a plant! However, I have found suitable pieces of root on walks in the Pennines - particularly where old rhodedendrons have been cut back. A big advantage with root material is that it is very tough (wiry) and less brittle than branches. Heather has similar properties.
Check out this link …..
http://www.009.cd2.com/members/how_to/trees_hedges.htm
