Scenery ground cover
(In Topic #11198)
Railway embankment
Hi All This is another" bright idea " I had today, but, I said today, as I have got to test it. Someone might have already tried it and failed?? My idea is "Oasis" the green stuff used by florists for flower arranging, it is available on line. The idea involves following tree making tips on "Y M R C", and then sticking the home made trees into the "Oasis" the way it was meant to be used, and it comes in a nice green colour just right for embankments. ATB KevinUpdate! Upon further research, I have discovered that there are two types of "Oasis Foam", the one required is for Dry flowers!
Looked at this as I have a relative into flower arranging.
Do not know what it is like in the UK but here in Sydney it was cost prohibitive. I found that the local Bunnings (large hardware store) had large sheets of modelling foam (extruded not expanded) for less than a small oasis block. Just not green.
Andrew
Last edit: by 60019Bittern
Having read your first post, I now understand what Oasis Foam is. I will add that I replied to your PM prior to reading this. One thing that I do know about this type of foam is that it will disintergrate when exposed to heavy moisture or water. I would aim at either polystyrene or styrofoam for scenery building and avoid the oasis foam altogether.
Last edit: by Gary
Invest in a hot-wire cutter and use the expanded high-density foam (pink or blue, not the white, that's low density and crumbly). The florist green foam is not stable.
The same plastic prill raw material but a totally different manufacturing process with "extruding" being far more expensive than "expanding".
The bobbly expanded stuff cuts like butter with a hot-wire cutter. I've never used a hot-wire cutter on styrofoam but had assumed, being much higher density, it would tend to melt and stick to the wire leaving a stringy mess. Just shows - you live and learn.
Incidentally, the expanded stuff comes in a large range of densities from extremely soft to very hard and even a fire retardant version.
As Gary said, Oasis will disintegrate after prolonged exposure to high humidity, sunlight or very dry conditions. It behaves a bit like the foam underlay from the likes of Peco only faster ……………..
HD foam is cut to size at the factory with hot wires. Just a bit slower than the low density foam. Less mess than the kitchen knife. Woodland Scenics do one. And it can be carved with a hot knife.
http://woodlandscenics.woodlandscenics.com/show/category/BallastAndCoal
has this line ALLERGY CAUTION: Contains tree nut by-products.
