Tramway making
Henryparrot attempt at producing a tramway
They seem fine running on the bench. I have to assemble the tram, decoder, etc., so it might take a day or so before I can tell how they go in anger. :lol:I'll try to do the mod. pics tonight. :thumbs
Exploded view showing the tabs folded in.
Tabs folded up.
Tabs folded over.
Wires soldered on. I didn't have orange and grey, so I used green and white; but the red and black are right.
Can you test yours see if they run smoothly and dont make a grindy noise and are not lumpy?
I've tested them and they run smoothly and only make the "electric motor" sound. I did find, however that the track must not just be clean it must me sanitised. The SPUDs have chrome plated wheels (possibly brass) and any trace of dirt makes them lumpy. Not like your regular production locos at all.
With this info i am now seriosly looking at alternatives before i do or purchase anything else
thanks for that info Max
cheers Brian
I suspect that if I could add some weight, it might perform a bit better, but where to put it?
It also occurs to me that your SPUD might just be worn out - and you have only 4 wheels for pick up, whereas I have eight, so everything is working against you.
I have always wondered why more people don't run trams . . . :pedal
yes mine is certainly worn and not in tip top condition and it only picks up on that bogie what also does not help when in the tram it is very top heavy because the litlle blue tram overhangs the bogie by a long way each side so it does not take a lot to make it unstable with a double bogie like my red one that would not occur.
i have not given up on it yet but i do have an alternative wicked plan if i do
cheers Brian
from Bachmann
pickup on 4 wheels & the slightest bit of crap on the track & they stop.
Would it be possible to put some wiper pickups under the drivers compartment Brian ?
Yes that thought has crossed my mind because as it is certainly my single bogie unit is on a hiding to nothing as it is
cheers Brian
