Hi Spurno/Alan (don't know which you prefer)
The images are from an out of print book "The British Tram" dated 1963, cover price 5/-. The author is Frank E Wilson and publisher Percival Marshal now acquired by MAP but no longer in their catalogue.
Mr Wilson did not record any copyright details and as he was born in 1905 I do not believe I, or YMR, to be infringing his copyright.
Obviously if you think there is a problem I will happily remove the pictures.
Sorry for the hiccough.
Jim.
Hi Jim,i hope you wasn't offended by my asking but when i took over from Bob one of the things i became aware of was copywrite so i have to be carefull and without the information above i couldn't be sure.
Not offended in the least. Had a few copyright arguments myself but as webmaster you need to be extra careful. As a user I need to stick to your rules. So what is your decision, do the pics stay or, go?
Look forward to hearing from you.
Jim.
The Mark Hughes offering looks good and I've been told it's probably the best on the market. Never having seen one "in the flesh", does it come ready bent to shape or just as a piece of wire ……………? :roll:
It's an etched brass kit, but there are only three main components. The Base, the Bow and the Spring. You fold the base up in three places at each end to form a pocket for the spring ends and the bow is a mirror image of a bow which you simply fold over and solder for strength. It's so simple it borders on genius. I'll be getting
Jim
I'd already decided these are the bows I'll use when I start motorising my EFE trams - with Halling motors. :thumbs
What are the dimensions of the Halling motors, and are they just motors or full bogies? I need something to fit under this but it's
an open car with no space to hide an intrusive bogie.
Also this is the picture I was looking for about the Mark Hughes bow kits. Apart from the instruction leaflet this is the entire kit.
and that's in the picture as well as it's the sheet the bits are sitting on.
Jim
Halling makes a pretty big range of motor bogies. I think I've got a couple of the KSW type for my EFE Leeds trams - not fitted as yet ……..
They're much better quality motors than the old BEC type but don't have any means of fixing them to the tram body. I've seen a metal plate glued to the body and the motor magnet simply "snaps" onto that. Also, a "grab" made out of plasticard that clips around the front and rear of the motor.
Not cheap but have a look at his site - it's quite interesting:
Halling, Ferro-Train, Stängl - Home
That is going into Bookmarks
It still looks like they will intrude into the lower saloon. However it will take me a while to dig out the info I need as there is no translation on the data pages.
Mind you that's probably better than the data from these guys, TOO much.
Code
http://www.hollywoodfoundry.com/shopdisplayproducts.asp?id=10&cat=BullAnt+Drive+MechanismsThanks
Jim
I've only got a couple of the motors but I'll buy more when I get round to doing the tram circuit (and some Mark Hughes bows ………;-)) I found the BEC type motors to be real pigs at anything less than flat out ………….:???:
You said
True, and even then if you have two hitched to a bogie tram one runs faster than the other and you end up with the bogies tipping into the centre of the tram and stopping it that way so you need to run flat out and the weight of a white metal kit to keep it flat.I found the BEC type motors to be real pigs at anything less than flat out ………….:???:
Mind you, "flat out" is not exactly HS2 performance.
Jim
Well, Leeds did use Felthams and you can get kits, but since this is the card model thread,THIS is out there somewhere although I can't vouch for its scale. As far as I can make out it was a giveaway from the "News of the World" so there should be no copywrite problems but just to be on the safe side I have printed it, added the front of a Glasgow tram, half sized it and scanned it in so that it's my picture. Ive got the drawings for a "Feltham" so I will rescale it.
Jim
Got to thinking, always dangerous:mrgreen:, about the justification for running "guest" trams on a layout intended to represent a specific system and realised that I was thinking about it the wrong way round. What trams will NOT look out of place on any system?
Permanent way or other works cars! So you can put, for example, a model of the cable laying Glasgow car on your proposed Leeds layout and it will look fine. I might even be able to cobble one up using some of my "standards" bits and some Scalescenes planking.
Jim
Just spent an instructional afternoon with the Bachmann Hong Kong tram as a prelude to fitting the bow for overhead collection.
To be honest I've fitted the bow but not connected it up yet [waiting for the glue holding the wiring from the bow to set before I start messing with the wiring harness]. I have learned that putting nuts onto 1mm screws on the internal roof of a double decked tram in 4mm scale is not easy as my fingers do not reach to the screws. A bit of 3mm OD brass tube works as a long socket spanner.
The pic below shows the motor under the tram and it seems to be only about 8mm thick so it will fit under my Glasgow standards. As made it has an 8 foot wheelbase so will go under a round dash car "as is" and only needs to have the wheelbase shortened to fit the hex dash cars.
I have also discovered that it will be reasonably easy to switch to overhead as all you need to do is desolder the red wire in the pic from the pickups and connect it to the bow. To complete the transformation to two rail and overhead you need to solder a lead from the original fixing point and connect it to the pickups on the other side. Doing it this way saves messing about with the rest of the wiring loom.
As you can almost see here there are a couple of resistors in the circuit and I still have not discovered if they are to protect the LEDs or reduce the voltage to 6volts as I don't know if this is a 6 or 12 volt motor..
On the subject of pickups removing the motor and wheels and bending the pickups out a little improves the running qualities no end. Right now the tram is trundling round Proven Mill on it's running in period. I have still got the bodywork off to allow me to finish the modifications and it's wandering round and round like a double deck toastrack.
Jim
Last edit: by The Bankie
Reproduced below is their reply.
Now call me Mr Cynical but this looks like the alternative and polite version of "Sod off, You're not a dealer and so you're of no interest to us.". So it looks like I need to investigate sensible alternatives and customer focused companies.Thank you for your enquiry. Unfortunately we are unable to help you on this occasion. Whilst we have limited spare parts provided to us for the support of our models after purchase: we don't have them to supply for other modelling uses. Regards Service Team Bachmann Europe plc
I'll let you know how I get on.
Jim
Well the conversion to a bow collector has worked extremely well and the Hong Kong Tram now runs on live overhead and twin rail return. Right now it is hampered by the state of the overhead in the picture. Despite this the tram got to where it is under its own power and with no assistance, the sett car was only plonked on the track as window dressing. No it's not very far but it was a successful test.
Later it even managed to reverse under the slack wire. Concerning bow collectors and reversing I got an email from Andy Bailey, one of the fitters at Crich, who was kind enough to assist me when he caught me sneaking round the workshops and who expressed an interest in 00 tramways.
Here is what he said,
So there we go, info from someone in the know.Jim, Regards the bows you mentioned, the only place I can think of that turned bows in Britain would probably be Sheerness who used Siemens equipment which was unobtainable during WW1 and led to the tramway closing in 1917. hope this helps
Andy
The second picture just about shows the bow and the new poles and one of the Mark Hughes hangers I am installing on Proven Mill. Installation will continue when I get some more 4mm OD tube to make the different thickness pole bases.
I'll keep putting on progress reports but this is NOT my personal thread:shock::shock: so how about a bit of company on here?:lol:
Jim
:cheers
Nice to see you visiting our thread :).
Wahiba/David has already said that he uses these bogies as tram motors but there are a couple of snags.
- Underground Ernie is discontinued.
- It was a Bachmann product and whilst the products are good the company are not exactly customer friendly. Underground Ernie is a discontinued line and they don't even admit to issuing it as I found out when I inquired about spares.
- My working clearance at the moment is 9 mm to the track top so currently I am inquiring about Nigel Lawton motors.
- at correct scale sizes my maximum wheelbase on a bogie is 20 mm.
Wahiba uses models with opaque windows so the height question does not arise (OUCH dud unintentional pun :oops:) for him. You can motorise the trolleybus or tram using one but today you need to find one. I CAN possibly use them as the truck on the standard trams if I alter the wheelbase and put 9 mm wheels on it.
The same goes for the Hong Kong trams although the situation is a little better there as they have a scale 8 foot (32 mm) wheelbase which will fit under a round dash Standard with only the wheels replaced with 9 mm ones.
So can I add a plea to this post for any unwanted Hong Kong Trams? The models are quite good so I am loth to rip them apart simply for the motor and gearbox. Obviously financial compensation will be offered.
Regads
Jim
