Auto points operation.
(In Topic #9493)
index02
index02
Or have I got the wrong end of the stick.
David
index02
index02
Last edit: by RFS
Robert
Last edit: by 60019Bittern
You could use IRDOTs in place of isolated sections of rails , that overcomes common return concerns, but I am not sure if the IRDOT relays would like the heavy load of solenoid coils - usually 3-4 amps whether DC or AC.
David
index02
index02
The switch that is triggered would have some kind of time delay to stop it being activated by subsequent sets of wheels from the same loco. A couple of seconds would be enough to let the loco clear the points.
This may work on routes where loco's only travel in one direction like a dedicated up line or down line. There again, I may be waffling complete rubbish.
Might be something to work on if you have the head for electronic gizmos.
Maybe not .
Toto.
Andy
Andy
Tell me if I'm one slate short of a tiled roof.
redirect to IRDOT-3D
To change polarity
Useful for allowing trains to run non stop around DCC reverse loop
I've not lost the plot after all. I would still need to get my head round it totally but the actual theory is there.
That's a step forward.
I did have the old operating mail coach which I seem to remember had to have a couple of trackside levers/switches which had to be placed a certain distance from the pickup/drop off points, but the details are lost in the mists of time.
We're all thinking electronics and was just wondering if this could be done with some sort of trackside switch just operating a point motor as Petermac said.
I'm thinking from David's OP we're talking trams and not long trains.
Might be wrong, back to the original post me thinks.
Last edit: by Gary
http://www.maplin.co.uk/p/assemtech-miniature-reed-switch-no-cl38r
These could be buried in the track bed and operated by a magnet on the train/tram or whatever.
I've never used reed switches before so would have to get my head around the principle of how they actual work/ operate. I think between that and the IRDOT gizzmo that Sol highlighted, there would be a solution and a reliable one at that.
I need to do a bit more reading on both to see which would be easiest.;-:hmm
I picked up a simple diesel horn system where you put reed switches at positions around the layout and when the loco with the magnet passes the switch it triggers the system to sound a horn.
Andy
Andy
