what surface
concrete
Try Plasticote suede paint for concrete
Hth
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
An update on the concrete surface for the industrial area.An absolute disaster i'm afraid.I think i put it on a bit thin and it cracked,but not small cracks,it actually lifted.It looked like a dry river bed.I'll try again tomorrow and use pva to the mix.Oh well onwards and upwards.All good fun i suppose.
Hi Alan.
Maybe I should have mentioned it, and If I didn't I apologise after all the work that you must have put in - yes,mix in PVA glue next time and that should hold it firm - however, may I suggest that you try it out on a test section first?
My apologies.
Allan.
Anyway, maybe when you tried it the first time you tried it on an absorbant surface where it would have drawn most of the water out of the mix.
However, since you've now mixed PVA in with and primed the surface, it should turn out just fine - 'stick' with it and please let me know how you got on.
Cheers.
Allan.
I've used water putty to good effect before now. But the cement/PVA mix has my interest, looking forward to seeing the results.
That could be something many of us tried to achieve without success Alan. :shock: Did you photograph it ?……………………………………………….It looked like a dry river bed……………………………………
I ask this because all you really need is a single coat no thicker than a coat of emulsion paint say and this shouldnt crack and even if it does, it will only be hairline cracks at the most.
Curling up is quite normal and you should be able to glue this down to the sub surface either using Impact adhesive, or PVA weighted down.
Best regards.
Allan.
I'd have thought you ought to use the cement powder in the same way the talcum powder is used - i.e. "brushed" on like paint with texture in it rather than "laid" as a thin screed. It would almost certainly crack as a screed but as a "texture" in paint, it ought to be OK.
Just a thought !
Hi Alan.Hi Allan,about 1/16" which is about as thin as i can get it.It's a bit difficult to get it thinner as it drags up on the scraper.
All I can suggest is that you use a wide brush to spread the mix instead of a scraper and just keep wetting the brush. As the slurry dries, it should level itself out. A light wet stippling will also help to level it which can then be sanded down after it has dried.
Now I think that there are, or were, different coloured texture paints available - tarmac, concrete etc - which in effect are ordinary emulsions impregnated with fine grit which were made for this very purpose - textured ground effects.Or, and as more or less already suggested by the guys, you could try mixing the cement powder with white emulsion which might spread a lot easier without clogging up.
Anyway Alan, keep us all informed - I can see a massive modelling breakthrough in the making here !
Allan.
Last edit: by allan downes
The thing to remember about concrete is that it gets its colour from the sand and aggregates used, not from the cement itself which, as you've probably realised, gives a greenish colour. I would suggest you go out and take some photos of the sort of concrete colour you want. I find the best way of reproducing concrete is to use plaster of paris with either powder paints or artist's acrylic paints mixed in to get the sandy colour you need to match your chosen photo.
I hadn't thought about plaster of Paris - cheap and sets before you can blow your nose ……….but very brittle unless it's well supported:thumbs
Have you tried exterior "stone paint" ? It's exterior wall paint with very fine aggregate mixed into it to give some texture. Again, for the tiny quantities you need, probably not a practical solution. :roll:
