Layout building construction methods Card or Plastic?
(In Topic #4356)
discussion to outline pros and cons of both
The subject of which method of construction to use for buildings on a layout crops up time and time again and always the same debates begin over the pros and cons of different building methods.As with all things, personal preference of an individual plays a big part in the method they promote to be the best. What I would like to achieve with this thread is to create a reference for all members that can be used by them when deciding what methods they should use on present and future projects.
So if many members can forward their views that will be helpful and we can edit it at a later date to make a good reference thread.
So to start this off I have highlighted a few areas that need consideration when deciding what construction method. If anybody feels there are more areas please post and they can be added to the list.
I will give a brief synopsis of each area but these will be enlarged shortly with more description. Bear in mind some areas, in some case,s cross into others sometimes
Layout Environment:
Where is your layout situated? is it in your home in a centrally heated room or is it in your shed which is a bit damp and widely changing temperatures. Where in the world you live - the climatic conditions
Cost:
Dependant on each individual this is an important factor plus of course the size and number of buildings required also affects this area.
Construction timescale:
Again this will vary dependant on many factors like available modelling time and amount of buildings
Longevity of models:
What is the anticipated life expectancy of the model? this does need to be taken into consideration.
Skill level of modeller:
This has to be taken into account as we can't all be doofers or Jim Sw
Overall look wanted of model and its position on layout:
This should spark some good discussion as this aspect often can be one of the deciding factors in what construction method to use.
Please feel free to add and comment of any of the above and feel free to add sections and put your views across on any of them.
cheers Brian
William
lets just say there is no 'or' about it for me. Its very rare indeed that I will only use 1 type of material in the construction of a building. Even something simple like a retaining wall will be made up of a combination of Foamboard, card and embossed plastic. The finished surface will depend on several factors, what is the texture that I want. Card is good for concrete as its not super smooth. However if I need to scribe lines on it with a scriber then the sriber will tear the surface of card so I use plasticard instead. This will then need the texture adding back in later.
For sub structures its usually foamboard or perspex depening on how much of the finished structure is 'glass'. Sub structures are normally card and the top surface normally embossed plastic.
HTH
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
I do like the Scalescenes papers for brick, tiles etc as they have a slightly weathered finish that I would find hard to produce better myself, but where I need to have a specific painted finish on a building, such as corporate GWR colours for example then I prefer to paint on plastic. I often use a combination of materials on the same building.
My layout is in a cellar which is dry and keeps a reasonably constant temperature of around 60f and i've not had any problems with card warping
For texture, I think plasticard is unbeatable although often "out of scale" - the use of 7mm stone sheets on 4mm layouts being an example.
I like the speed of plastic - a quick slice with a sharp knife, snap along the line, a quick wipe with solvent and it's stuck. Painiting is another problem area for me !!!!
Card, even with "sticky" glues, takes time to set and I'm never totally sure about how good the bond is but at least I can cover it with printed papers.
On the other hand, card is most definitely much cheaper (if it's not free) than plasticard. I also find it harder to work with.
As I don't currently have a layout in place, the "environment" isn't of importance to me.
My only attempts at scratch building are in plastic and I have enjoyed what I have done.
I never seem to be able to get the brick papers to stick to the card to a standard that I am satisfied with.
