How do you do car windows
(In Topic #8803)
Solid cast white metal ones that is.
How do you finish windows on solid cast vehicles? white metal or resin.(probably more applicable to N gauge)Do you paint them, if so what colour, or do you leave them as bare metal? Resin I think would need a grey or silver.
Hollow kit ones you can usually stick some acetate sheet in before assmbly, but the solid ones need a bit of thought.
While I haven't done any vehicles this way, I did do a Townstreet brick station building (in OO) this way as the windows were cast in solid plaster like the rest of the building. I would deem it a successful treatment. You can see something of the effect in the photo below.
The Harry Potter Knightrider bus was still under construction here, made from two EFE RT/RTL buses.
Another product is Testors 'Clear Parts Cement & Window Maker' see here ; http://www.amazon.com/dp/B0006NDZDU
What I'm asking is how do you make white metal look something like glass, and remembering that many 1930s cars were black.
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
I would be inclined to use a dark to mid blue which acts as a reflection of the sky and if you can shade it lighter towards the bottom of the window (I would have no hope as I find HO small enough).
I would then go over that colour with one of the glazing liquids, I use Glue and Glaze which I find great to use as nay spills can be rubbed off when dry. This should give you the right colour and a nice glossy finish.
Simon
Any attempt to paint it has to be perfect or it looks awful.
Kristal Klear and similar products ore fine if you have a hollow kit, although where possible I would use acetate sheet, if you read the original post, you would see I'm asking abour solid cast N gauge cars and some other vehicles, the windows are just shallow depressions in the casting, maybe less than 1mm deep, not a hollow body with holes for windows that need glazing.
I should of made myself more clear. You can use this over the surface to act as a clear coat to give that glazed look… By all means paint the surface first, black, silver, blue, whichever, then coat with the above mentioned products.
I don't find silver or lighter greys convincing colours for windows - look at some of the illustrations in adverts for finished versions of the Graham Avis resin models in N scale where they have used a light to mid-grey colour.
I agree that dark colours would look better - if it is a black car then use a dark grey or dark blue as per Simonmcp's suggestion. I also like his idea of shading it from darker to lighter blue but you would have to experiment a bit with that to get a consistent finish.
